Home > Maintenance & Modifications > Puma 2,4 Engine upgrade
Page 2 of 3 <123>
Porny
Site Sponsor
Lol.... just for fun (and during testing of speed limiter)
2.4 Tdci Puma.
- this in it's latest guise, though will be on the dyno again soon.
A rolling road is a useful tool when it comes to proving what power/torque the vehicle actually makes, and it helps when you can hold a vehicle at a set speed and fully load it - which is a massive help when looking at turbo control.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #201675 14th Jan 2013 10:56am
jst
Naks, can you keep us posted on how you get on once you have taken the CAT out. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #201723 14th Jan 2013 2:40pm
pepekleinhans
South Africa
Wow Porny, that is awesome, thanks very much for this, you guys have done great stuff on the 2,4.
Know I just need to get mine done.
Thanks very much
Pepe 2005 Discovery 3 HSE
2007 2.4 Puma Defender
1976 series 3 with Ford V6 engine
Post #201727 14th Jan 2013 3:10pm
pepekleinhans
South Africa
Naks wrote:
Regard wrote:
And since there are less traffic cops on this site compared to the local site......I will admit that I have once tested it and yes, I also did 160 odd Km/h. Whistle
I was deaf for about 3 hours afterwards though..... Thumbs Up
Rolling with laughter
Post #201728 14th Jan 2013 3:12pm
Naks
Yep, will definitely do. Landy is booked in with my indie on 25th Jan to remove the cat.
I'm in two minds about removing the centre silencer box as well... --
Post #201741 14th Jan 2013 4:21pm
K9F
I removed the cat and the rear box in lieu of the centre one. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201747 14th Jan 2013 4:42pm
BruceT
South Africa
Rolling with laughter Rolling with laughter @ Regard "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #201943 15th Jan 2013 6:39am
Naks
Ok, but the centre box imposes more restrictions than the rear box, I'd rather get rid of the most restrictive stuff? --
Post #201944 15th Jan 2013 6:47am
BruceT
South Africa
Agreed do the centre box Naks..... "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #201945 15th Jan 2013 6:49am
Naks
Yeah, I think I will. And I will keep the silencer. This way if SWAMBO complains about the noise, I can refit it without her finding out what I did Wink --
Post #201946 15th Jan 2013 6:53am
BruceT
South Africa
Rolling with laughter "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #201947 15th Jan 2013 6:53am
bell-auto-services
Id be interested if anyone fancys the test to know what removing the guts from inside a cat V a real decat removal pipe does for the exhaust back pressure, its known that some decats or exhaust systems can cause problems especially with surging due to thepressure being so low inside the exhaust.
Most can be mapped round but it does beg the question is a decat is worth the extra effort at all considering some cars will need a lot more work to make run correctly after a decat is fitted.
here are some pictures of how I measured some temps and the exhaust back pressure on the original 2007 developement of which I see a few in this thread will be running the mapping knowlage from.
http://www.defender2.net/forum/topic5632.html
Im not saying dont ever remove the cat but I am saying be carefull as some cars can run worse with it out!
Regards Pete
Post #201979 15th Jan 2013 11:24am
Naks
Interesting comment Pete, is the exhaust back pressure even monitored by the ECU? --
Post #201980 15th Jan 2013 11:27am
bell-auto-services
its not monitered no, but the turbo and some other engine components are build and designed round a known exhaust back pressure as this is always assumed to be standard factory.
pete
Post #201981 15th Jan 2013 11:28am
BruceT
South Africa
Regards Pete
Pete I would be very interested in the results of the decat test and whether its worth it. I have also heard that the removal of the cat aids in reducing cabin temperature. Is this true?
I am about to decat my puma and now you have put doubt in my mind>>> Very Happy
Thank you. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #201985 15th Jan 2013 11:33am
Page 2 of 3 <123>
