Home > Maintenance & Modifications > Alisport Intercooler |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
We tried that, but the pins would not come out, we tried both sides. Oh well, now I know -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jan 2013 9:44am |
Just thought of this now - should I ask BAS for a new map with the intercooler? --
9th Jan 2013 11:26am |
Yep, BAS said the same thing. All I can say is, with the intercooler the truck just pulls and pulls, and whereas before I had a flat spot in 6th, now it just keeps going -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jan 2013 2:03pm |
DavidITGuru Member Since: 15 Aug 2011 Location: London Posts: 99 |
Might I ask how much it was?
Am quite interested in doing the same especially as there's still no map available for the 2.2. Thanks in advance. |
9th Jan 2013 3:26pm |
For me in South Africa it was expensive due to exchange rate, but check prices with BAS. You are looking at around 420 pounds. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jan 2013 4:05pm |
Those of you interested in the difference between OEM & Allisport. see this thread on 4x4community about a comparison of standard vs upgraded intercooler: http://www.4x4community.co.za/forum/showth...amp;page=4 --
13th Jan 2013 10:02am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
sorry Naks but again. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
15th Jan 2013 11:57am |
rusty66 Member Since: 22 Jun 2010 Location: Rhineland Posts: 60 |
Greetings,
What did you do with the hoses if I may ask? Did you swap for silicone ones? And hose clamps? I have seen somewhere clamps that don't seem to cut that much into the material. This might sound a bit over the top probably, but once I'm at it, I might just as well do that, too, if it's recommended. Cheers Boris |
15th Jan 2013 8:31pm |
Boris, I used the same hoses. Had I known what a mission this would be, I would have also gone for silicon hoses. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
16th Jan 2013 5:24am |
Thanks Naks,
It's probably sensible then to swap the hoses in one go with the intercooler. So another hundred quid more ... |
16th Jan 2013 7:41pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
its a wee bit chilly outside at the moment.....(just been looking around under the bonnet and under the car - so I know)
and it made me wonder if the IC upgrade would be a backwards step in cold climates / this time of year in the UK ? |
16th Jan 2013 8:55pm |
Well, it definitely drives better these days with minus 8 degrees around here. Pulls better and more smoothly, i think.
16th Jan 2013 9:05pm |
cheers. - I guess that answers that.
16th Jan 2013 9:15pm |
Yeah, for you UK guys a bigger intercooler is a bit wasted. I mean, you people think a few days of 25C eather constitutes a heat wave Anyway, some more feedback on the intercooler after the landy spent a week at the stealer for a new clutch: 1. Lower EGTs allround, esp when going uphill 2. A small flat spot in 6th that used to prevent me from shifting into 6th on long uplhills is now gone 3. The landy just pulls and pulls and pulls, more noticeable on long uphills -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
18th Jan 2013 7:18am |
