![]() | Home > Puma (Tdci) > Second service @ £541.85 ! |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 ![]() ![]() |
Wow
Just had my second service for my Puma 2007 at the Dealers, a whopping £541.85 ![]() |
Cor Blimey!
You need to find yourself a decent independant! Mine quoted approximately 2.8 manhours at a cost of 'about' £350 + vat for the same service. Would take you about an hour and a quarter to get to him in future from where you are (60 miles each way), courtesy car on offer as well! I use him on a regular basis and travel myself an hour to use him. The only thing with independants is they cannot do warranty work as a rule. Nevertheless if it's a small fix they'll do it for you. Whatever way you look at it it would still save you a ton. If there's not a decent independant closer to you here is the linky thingy: http://www.james-french.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
![]() '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2467 ![]() ![]() ![]() |
That is a lot. I paid GBP50+oil&filters. Puma 110" SW
Fekete, your independant was cheap! May have to move oop north!!! (Don't think so!). Just added my independant to the Dealership Feedback Thread. Finding my way round this site a bit now! Good innit?
![]() Treat every day as if it is your last....one day you will be right!! |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Is that schedule because of your location. i.e temperatures and dust? Puma 110 - gone Series III 1973 - going strong |
Correct, the climate here is hot and humid. Its a desert environment and temperatures can reach upto 52 degrees. '08 LR Defender 110 '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
Yes this site is good, Heres my independent just schroll down and they have all the pricing there http://www.deeside4x4.co.uk/servicecosts.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Good value Fekete,
Being a Southern Central Heating For Tramps (cider) drinker what begs the question from such a northern independant - Do they allow you to take their whippet out for a walk and ask you to wear a flat cap whilst your Land Rover is being serviced? Off topic I know but couldn't resist a little banter! ![]() Treat every day as if it is your last....one day you will be right!! |
Yes and they have 4, all supplied with sh!t bags
I likes my cider.....and when I drinks my cider......my arse gets wider.....and then I fart!!! NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Nearly fell off my bl00dy chair and cracked a rib!!!!
![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Is there any truth in the rumour that there is an imaginery line that runs from Watford to Gloucester and any pidgeons that cross this line heading north start flying backwards to keep the
![]() Nearly said 'birds' instead of pidgeons but didn't want to upset any females! ![]() ![]() (Apologies Diffbeer didn't mean to hijack the thread. Being a fellow southerner I hope you understand!) If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 15th Dec 2009 12:23pm. Edited 1 time in total |
Joking aside just looked out the window and seen to old chaps with flat caps
