Home > Technical > HEAD LIGHT FLASH FAULT PUMA
ross0602
England 2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Good afternoon,
My 110 xs puma has devloped a fault. The head light switch when you pull back on it to flash wont work. Main beam still works. I have checked all the fuses and none are blown. Tres confused! Rolling with laughter
Any help would be good. Thanks 110 xs ute. 2.2
Post #199959 8th Jan 2013 3:58pm
Probably not what you'd like to hear but I would imagine the stalk has developed a fault. (especially if the fuses are all okay) Is it under warranty? KEEP CALM AND Drill ON
Post #199962 8th Jan 2013 4:04pm
ross0602
thanks for the reply. it had a new one on 6 weeks ago. 110 xs ute. 2.2
Post #199964 8th Jan 2013 4:07pm
Ah, it's probably not that then. Confused KEEP CALM AND Drill ON
Post #199967 8th Jan 2013 4:09pm
ross0602
will have a look at the weekend 110 xs ute. 2.2
Post #199973 8th Jan 2013 4:30pm
If you have a look behind there with a multimeter and do a bit of testing I'm sure you'll find the problem out. With no fuses blew it might perhaps be an earthing issue instead.
Good luck. Thumbs Up KEEP CALM AND Drill ON
Post #199976 8th Jan 2013 4:33pm
ross0602
I will have a look. It will be a wire fault. as it is a landy Laughing 110 xs ute. 2.2
Post #199980 8th Jan 2013 4:40pm
Happyoldgit
If it's just the flash that's not working and the constant dipped & main beam are ok my first check would be the brass contacts for the flash switching on the stalk. Steve.
http://forums.lr4x4.com
Post #199995 8th Jan 2013 5:13pm
