![]() | Home > Technical > Clicking clutch pedal? |
Try a bit of lubricant on the pedal spring and while you are there check the plastic insert that the spring fits into on the pedal shaft is still in place. Steve.
If you have the long straight return spring it wears and eventually clicks when the pedal is released. The fix is to buy a new spring as it is the spring itself that wears. Alternatively you could take the opportunity to fit the spring "upgrade" which also makes the clutch pedal a little bit lighter to use. See this thread http://www.defender2.net/forum/topic6616.html |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
I will have a look tonight and see what's going on as it has only done 3200 miles so back to LR if needs be as warranty claim will be going in
does anyone have a picture of what im need to check or look at?
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
Hi, I understood that 'spring upgrade' comes already with the TD4? Anybody knows that? |
Not sure, it defo came as standard on late 300tdi Defenders and then reverted back to the straight spring for TD5s... |
Puma has the pedal mod as standard.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3654 ![]() ![]() ![]() |
Mine did the same, very annoying bit of spray grease around the pivots and the spring cured it DEFENDER 90 TDCI XS,
Yes it does. The spring I'm on about is easy enough to find, it's circular and locates in a notch just above the pedal pad itself. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
