Home > Technical > Clicking clutch pedal?
Defender-Stu
Hi guys,
It's prob nothing as the truck drives like normal but when I release the clutch pedal it clicks once and I can also feel it through my foot? Is this normal? as i had not noticed this before?
Thanks for you help in advance Thumbs Up
Stu
Post #199624 7th Jan 2013 7:01am
Happyoldgit
Try a bit of lubricant on the pedal spring and while you are there check the plastic insert that the spring fits into on the pedal shaft is still in place. Steve.
http://forums.lr4x4.com
Post #199669 7th Jan 2013 12:47pm
geobloke
If you have the long straight return spring it wears and eventually clicks when the pedal is released. The fix is to buy a new spring as it is the spring itself that wears.
Alternatively you could take the opportunity to fit the spring "upgrade" which also makes the clutch pedal a little bit lighter to use.
See this thread http://www.defender2.net/forum/topic6616.html
Post #199686 7th Jan 2013 1:47pm
Defender-Stu
I will have a look tonight and see what's going on as it has only done 3200 miles so back to LR if needs be as warranty claim will be going in Thumbs Up
Post #199698 7th Jan 2013 2:16pm
Defender-Stu
does anyone have a picture of what im need to check or look at?
Post #199703 7th Jan 2013 2:43pm
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Hi,
I understood that 'spring upgrade' comes already with the TD4? Anybody knows that?
Post #199712 7th Jan 2013 4:17pm
geobloke
AlpenAndes wrote:
Hi,
Not sure, it defo came as standard on late 300tdi Defenders and then reverted back to the straight spring for TD5s...
Post #199716 7th Jan 2013 4:33pm
bob neville
Puma has the pedal mod as standard.
2013 Defender 90 CSW - sold
Post #199722 7th Jan 2013 4:59pm
LR90XS2011
Mine did the same, very annoying bit of spray grease around the pivots and the spring cured it DEFENDER 90 TDCI XS,
Post #199727 7th Jan 2013 5:07pm
Happyoldgit
Bob
Yes it does. The spring I'm on about is easy enough to find, it's circular and locates in a notch just above the pedal pad itself. Steve.
Post #199741 7th Jan 2013 6:13pm
