Home > Maintenance & Modifications > Defender thermometer?
Who has one? I swear I've seen the odd one built into the dash. Currently thinking it would be a nice addition. It's a shame LR didn't add one as standard the clock is very nice but no temp display. Sad KEEP CALM AND Drill ON
Post #199279 5th Jan 2013 9:08pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Mobile Centre do the Check Temp .
Looks like a nice piece of kit.
Post #199282 5th Jan 2013 9:12pm
That is nice. That was the sort of thing I was looking for but couldn't find. Thumbs Up KEEP CALM AND Drill ON
Post #199285 5th Jan 2013 9:18pm
Phoenix90
It does look nice, I do want one but haven't been able to justify the cost yet so have one of these for now.
Works well, but isn't backlit and doesn't look as smart...
Post #199287 5th Jan 2013 9:24pm
Yes, the mobile centre one does look smart if a little expensive (You get what you pay for) My issue was I was looking on E-bay and it's mostly Chinese rubbish on there. KEEP CALM AND Drill ON
Post #199288 5th Jan 2013 9:27pm
v40mav
These look good. Not cheap but I do miss not having one in the defender.
Anyone fitted one to their defender.
Keen to see an install and where the sensors need to be put Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #199297 5th Jan 2013 9:51pm
Hopefully some one will have one. KEEP CALM AND Drill ON
Post #199301 5th Jan 2013 10:00pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
dgardel has one on his defender....not sure if it is exactly the same, but it's very similar...search for his posts
edit: check this thread....it's on it...don't know where the original thread is
http://www.defender2.net/forum/topic3998.h...ture+gauge Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #199302 5th Jan 2013 10:03pm
excossack
For a cheap one, I was looking at http://www.ebay.co.uk/itm/In-Car-Digital-A...1e7024079a 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #199305 5th Jan 2013 10:14pm
^^^ I saw that too earlier but one thing concerned me and that was where to put it without it getting in the way. If it got in the way too much chances are I'd never use it then as it'd get annoying. KEEP CALM AND Drill ON
Post #199313 5th Jan 2013 10:46pm
excossack
Maybe above the rear view mirror, where the ash tray is on the dash (assuming you have a TD5), or over to the right above the dash binnacle? 1999 Defender TD5 110
Regards
John M0VAZ
Post #199315 5th Jan 2013 10:49pm
Puma for me so you probably have more room. KEEP CALM AND Drill ON
Post #199316 5th Jan 2013 10:50pm
Phoenix90
To be fair I had a similar one in my TD5 and always thought it looked a bit cheap and nasty and really out of place. It was also really sensitive to voltage changes, resetting itself if there was a surge of any kind such as using the winch.
The check temp looks much more OE when installed The other one I linked to looks OK in a puma on the blank side panel next to the centre dash but had to be placed carefully to avoid showing the cable (i wont be keeping it long term but replacing it with a check temp when funds allow so didn't want to drill any holes).
Post #199318 5th Jan 2013 11:02pm
I have one from Mobile Centre that I'm building in to the FCX 130, I'll update once its installed Thumbs Up
Post #199322 5th Jan 2013 11:33pm
i have fitted an UltraGauge (Brian/ Lorryman100) has written a great write up, this can display upto 7 screens of information and reset any fault codes etc and shows the airbox temperature.
see http://www.defender2.net/forum/topic11426....ltra+gauge
Post #199332 6th Jan 2013 8:23am
