![]() | Home > My Defender > My 2000 td5 90 project |
marsie Member Since: 17 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
Why thankyou
![]() ![]() Paul ![]() |
Now the chassis is done its time to start on the bodywork
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge Paul :mrgreen: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
Thanks Steve, i would think it would be possible to cut a hole in situ if you are very careful not to go through too far. Dont know how accurate my measuring is until i get the new body on my car
Measured??? is that a posh way of saying "guessed"?. Yep try to resist using a stihl saw with a 12" blade,unless you want a perfectly square hole in the top of your tank too
![]() Paul ![]() |
update time,been busy at work so not done much. Been getting bodywork ready for respray
![]() fitted a funky new steering wheel ![]() Click image to enlarge some sexy black leather seats (ebay specials ![]() ![]() Click image to enlarge and removed the lift kit and refitted standard springs. Also a snorkel ![]() ![]() Click image to enlarge Paul :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Marsie - You say you've done a few D2 axle conversions to Defenders, can I ask if you think it'd be viable to either A) Convert a 2003 110 Rear axle to take D2 air springs, or B) convert a 2003 110 Defender to D2 axles. I would need to retain standard components as far as possible, and do not need to run any oversized tyres.
Cant see why not. You may need to weld D2 type spring plates to the axle but the rear spring seats are interchangeable (bit deeper on d2) and then find someway of mounting height sensors etc. Also the chassis spring seat would need work- inner spring locator ground back and top drilled to secure airbag
Personally i would'nt fit a d2 axle to a 110 due to the weight issues. But no reason why you could'nt mod the salisbury?? 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE* 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
Oh yes
![]() ![]() ![]() 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 ![]() ![]() ![]() |
Yeah thought you were, I've seen the unit when I've been to the roofing place next door, the forklift looks the best way ha
Yep, thats us
![]() ![]() Paul ![]() 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
Update time again, not done much do to being busy at work
Fitted some ebay special wolf doors (will be getting new bottoms before paintjob but fitted these to checjk fit and alignment). Guy had no idea what they were worth ![]() [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Paul Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
EMPI748 Member Since: 15 Dec 2012 Location: Penicuik, Midlothian Posts: 50 ![]() ![]() ![]() |
Nice work. Those seats look ace, do you know what they are from?
