Home > My Defender > My 2000 td5 90 project
Page 3 of 5 <12345>
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
Why thankyou Thumbs Up . Must admit i had a bit of a headstart because almost every nut and bolt has been undone in the last 6 months so not too many rounded rusted siezed bolts Thumbs Up
Paul Thumbs Up
Post #148823 5th Jun 2012 11:48pm
marsie
Now the chassis is done its time to start on the bodywork Rolling Eyes . Picked up a reasonably good back body from a mate who is building a trayback. So spent a couple of hours rubbing it down and making an access hatch for the fuel sender and removed the cappings for blasting and galvanising Thumbs Up
Paul :mrgreen:
Post #148960 6th Jun 2012 9:23pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi Paul,
Love the chassis swap pictures, very interesting.
Do you think it is possible to cut the access hole for the fuel pump with everything in situ ? If yes and you have time then some measurements would be gratefully received. Smile
Thanks,
Steve
Post #148970 6th Jun 2012 10:18pm
marsie
Thanks Steve, i would think it would be possible to cut a hole in situ if you are very careful not to go through too far. Dont know how accurate my measuring is until i get the new body on my car Embarassed . May well have missed the target completely? Mr. Green
Paul Thumbs Up
Post #149056 7th Jun 2012 6:17pm
Steve B
Ha ha, hopefully you measured more than once Very Happy best of luck.
Yes, I understand it is close to the fuel pipes. Must resist from using the 12" disc cutter Laughing
Steve
Post #149164 8th Jun 2012 12:42pm
marsie
Measured??? is that a posh way of saying "guessed"?. Yep try to resist using a stihl saw with a 12" blade,unless you want a perfectly square hole in the top of your tank too Mr. Green
Paul Thumbs Up
Post #149214 8th Jun 2012 7:13pm
marsie
update time,been busy at work so not done much. Been getting bodywork ready for respray Rolling Eyes and-
fitted a funky new steering wheel
some sexy black leather seats (ebay specials Mr. Green )
and removed the lift kit and refitted standard springs. Also a snorkel Thumbs Up
Paul :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
Post #199062 4th Jan 2013 10:18pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Marsie - You say you've done a few D2 axle conversions to Defenders, can I ask if you think it'd be viable to either A) Convert a 2003 110 Rear axle to take D2 air springs, or B) convert a 2003 110 Defender to D2 axles. I would need to retain standard components as far as possible, and do not need to run any oversized tyres.
Post #199077 4th Jan 2013 10:49pm
marsie
Cant see why not. You may need to weld D2 type spring plates to the axle but the rear spring seats are interchangeable (bit deeper on d2) and then find someway of mounting height sensors etc. Also the chassis spring seat would need work- inner spring locator ground back and top drilled to secure airbag
Personally i would'nt fit a d2 axle to a 110 due to the weight issues. But no reason why you could'nt mod the salisbury?? 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #199080 4th Jan 2013 11:00pm
238kirk
United Kingdom 2003 Defender 90 Td5 SW Belize Green
Impressive chassis swap there Shocked looks like you know what your doing with that and done it a few times before, looking at the pics your work place is not too far from me, I know where to come when I want a galv chassis in the future Very Happy
Keep up the good work
Post #200569 10th Jan 2013 6:19pm
marsie
Oh yes Shocked done over 100 chassis swaps in the past 3 1/2 years but mine was a rush job done over a spare weekend (hence the forklift to get the body off Mr. Green ). We are at swinton so if you passing,call in for a cuppa Thumbs Up 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #200621 10th Jan 2013 8:42pm
238kirk
Yeah thought you were, I've seen the unit when I've been to the roofing place next door, the forklift looks the best way ha Thumbs Up
Post #200626 10th Jan 2013 8:54pm
marsie
Yep, thats us Thumbs Up . Forklift is certainly quickest way but not the best way to lift a shiny new puma body Mr. Green
Paul Thumbs Up 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #200630 10th Jan 2013 9:00pm
marsie
Update time again, not done much do to being busy at work
Fitted some ebay special wolf doors (will be getting new bottoms before paintjob but fitted these to checjk fit and alignment). Guy had no idea what they were worth Mr. Green
Paul
Post #250962 12th Jul 2013 9:00pm
EMPI748
Scotland 2000 Defender 90 Td5 SW Baltic Blue
Nice work. Those seats look ace, do you know what they are from?
Post #251161 14th Jul 2013 8:27am
Page 3 of 5 <12345>
