Home > Maintenance & Modifications > Led spotlight bulbs |
Ray,
it would be interesting to see how good H3 LEDs are on a side by side comparison. I'll probably be corrected, but I believe because these are spot lights, they do not have to be E marked ? You might also consider HIDs too |
2nd Jan 2013 8:38pm |
I'd not actually thought about the e marking. As for hid's I think I might struggle with mounting the ballast packs as the spots are mounted on an a bar. If I get time I could try and get pics of the standard bulbs and the led for a comparison but im not sure which I need with this whole canbus thing the shop is on about
2nd Jan 2013 8:48pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
The Defender does NOT use the Canbus system to identify blown bulbs. This is why some sites talk about using a resister. A LED bulb draws much less current and would show up as a faulty bulb by the vehicles electronic system without a resistor in circuit. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
2nd Jan 2013 10:21pm |
Excellent, cheers so I can just buy the standard led bulbs.
2nd Jan 2013 10:32pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Yes, just buy the most powerful LED replacement for a H3 you can find. I bought a single chip 5W Cree one in a standard bayonet fitting, which I put into the reversing light on the 90. A good improvement over the standrd 21W filament lamp, but would be disappointing if fitted to replace an H3 in a spotlight.
I'd be interested to see what LED lamp you can find that gives similar illumination to the H3 you're replacing. Pete |
2nd Jan 2013 10:48pm |
Just as a bit of an aside but do I understand this correctly, if a car has a canbus system and has led replacement bulbs taking place of normal filaments then the current consumption wouldn't be any different as resistors have to be put in the system to cancel out any errors. Sorry but this electrickery goes way over my head
2nd Jan 2013 10:55pm |
That's correct JWL. The vehicle that has a " Bulb out system" looks at the current draw/resistance of the bulb. A failed bulb has 0 current draw compared to a functioning system. Inserting a LED bulb into this circuit would indicate a failed bulb because it draws so little current/has a very low resistance. In order to fool the electronics then you increase the resistance of the LED bulb using a separate resistor.
That is why if you replace the indicator bulbs on the Defender with LED equivalents then the indicators flash very fast, as if 1 or more bulbs were blown. You either have to insert resisters in the circuit to compensate for the drop in current draw or replace the Indicator relays for ones that are made for LED circuits. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
3rd Jan 2013 5:36am |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 |
Pete, Where did you buy this? Cheers, Superspoons |
3rd Jan 2013 5:47am |
Replacing H3 55W by LEDs....... Lots of pitfalls it seems. On top of that I am pretty sure that putting LEDs into optics which have been approved for Halogens remains completely illegal, even for driving lights.
Interesting threads I think: http://www.advrider.com/forums/showthread.php?t=630595 http://www.st-owners.com/forums/showthread...inions-pls http://www.candlepowerforums.com/vb/showth...afe-to-use http://www.advrider.com/forums/showthread.php?t=438232 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
3rd Jan 2013 6:00am |
Great info, cheers you've just saved me a wasted journey and a few quid. Well I guess that idea is scrapped then
3rd Jan 2013 11:00am |
I got it from eBay. But to be honest it was so long ago that it no longer shows in my history thing. However, it was from this guy and looks exactly like this one: http://www.ebay.co.uk/itm/CREE-Q5-POWER-LE...564e40b7f8 Pete |
3rd Jan 2013 11:35am |
