Home > Maintenance & Modifications > Led spotlight bulbs
mk1collector
Led spotlight bulbs
Ok I've had a search but can't find anything that relates to this. I have a pair of genuine landrover 7 inch spots/fogs on the front of my 2004 defender td5 and fancy changing the h3 bulbs to led bulbs. The spots are wired into the high beam if it makes a difference but the question is can I just get the regular led bulbs or will I also need the resistor to stop any problems as the advertisers I've looked at just say later cars need the extra resistor. Any help appreciated Thumbs Up
Ray
Post #198490 2nd Jan 2013 8:23pm
Ray,
it would be interesting to see how good H3 LEDs are on a side by side comparison. I'll probably be corrected, but I believe because these are spot lights, they do not have to be E marked ?
You might also consider HIDs too
Post #198496 2nd Jan 2013 8:38pm
mk1collector
I'd not actually thought about the e marking. As for hid's I think I might struggle with mounting the ballast packs as the spots are mounted on an a bar. If I get time I could try and get pics of the standard bulbs and the led for a comparison but im not sure which I need with this whole canbus thing the shop is on about
Post #198501 2nd Jan 2013 8:48pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The Defender does NOT use the Canbus system to identify blown bulbs. This is why some sites talk about using a resister. A LED bulb draws much less current and would show up as a faulty bulb by the vehicles electronic system without a resistor in circuit. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #198518 2nd Jan 2013 10:21pm
mk1collector
Excellent, cheers so I can just buy the standard led bulbs. Thumbs Up
Post #198523 2nd Jan 2013 10:32pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Yes, just buy the most powerful LED replacement for a H3 you can find. I bought a single chip 5W Cree one in a standard bayonet fitting, which I put into the reversing light on the 90. A good improvement over the standrd 21W filament lamp, but would be disappointing if fitted to replace an H3 in a spotlight.
I'd be interested to see what LED lamp you can find that gives similar illumination to the H3 you're replacing.
Pete
Post #198525 2nd Jan 2013 10:48pm
JWL
Just as a bit of an aside but do I understand this correctly, if a car has a canbus system and has led replacement bulbs taking place of normal filaments then the current consumption wouldn't be any different as resistors have to be put in the system to cancel out any errors. Sorry but this electrickery goes way over my head Whistle
Post #198528 2nd Jan 2013 10:55pm
WelshGas
That's correct JWL. The vehicle that has a " Bulb out system" looks at the current draw/resistance of the bulb. A failed bulb has 0 current draw compared to a functioning system. Inserting a LED bulb into this circuit would indicate a failed bulb because it draws so little current/has a very low resistance. In order to fool the electronics then you increase the resistance of the LED bulb using a separate resistor.
That is why if you replace the indicator bulbs on the Defender with LED equivalents then the indicators flash very fast, as if 1 or more bulbs were blown. You either have to insert resisters in the circuit to compensate for the drop in current draw or replace the Indicator relays for ones that are made for LED circuits. Thumbs Up LANDYWATCH
Post #198547 3rd Jan 2013 5:36am
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
XS Pete wrote:
Yes, just buy the most powerful LED replacement for a H3 you can find. I bought a single chip 5W Cree one in a standard bayonet fitting,...
Pete,
Where did you buy this? Cheers,
Superspoons
Post #198548 3rd Jan 2013 5:47am
ericvv
Post #198549 3rd Jan 2013 6:00am
mk1collector
Great info, cheers Thumbs Up you've just saved me a wasted journey and a few quid. Well I guess that idea is scrapped then Whistle
Post #198574 3rd Jan 2013 11:00am
XS Pete
Quote:
Pete,
I got it from eBay. But to be honest it was so long ago that it no longer shows in my history thing. However, it was from this guy and looks exactly like this one:
http://www.ebay.co.uk/itm/CREE-Q5-POWER-LE...564e40b7f8
Pete
Post #198588 3rd Jan 2013 11:35am
