Home > In Car Electronics > Td5 90 CSW audio upgrade/soundproofing.
adseybear
Canada
So confused reading through the massive thread, so I thought Id start my own.
Looking to slowly upgrade the audio in my 90, and need some advice.
Currently I'm running the stock speakers under the dash, with a Sony headunit which I use to stream music from my iphone via bluetooth. Im useless with wiring, so will most likely need someone to do any of the more serious bits.
Where should I start?
Thoughts are a pair of rear speakers in some rear speaker panels, upgrade the under dash speakers and tweeters in the dash? Do I need an amp and should I upgrade my headunit?
What speakers to go for, it seems these would be perfect for the front and rear?
http://www.justkenwood.co.uk/car-audio.aspx/kfc-s1094-speakers
Whenever I pull up any trim or carpet etc. I'll be looking to add some sound deadening too.
First thing, ordering some of these:
http://www.mudstuff.co.uk/Defender_Rear_Speaker_Panels.shtml 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #196692 27th Dec 2012 3:44pm
Those speakers would be ideal front and rear. (same power but newer model of mine) You wouldn't need to upgrade the Head Unit unless you wanted extra features to it? You also won't require an Amp at all for the front and rear speakers as the HU has enough power to supply those no problems.
Regarding sound proofing most seem to either go for Dynamat ( My preference) or Noisekiller and of course there is other type's available though E-bay. There are members on here that have done their sound proofing so probably in a better position to answer your questions as I haven't got around to doing mine yet.
Any questions feel free to send me a PM. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #196698 27th Dec 2012 3:55pm
Killer90
Site Sponsor
As steve said Dynamat is the one, butt is costly, it cost me £130 to do the back of my 90 and i still got the sides, roof,door cards and front to do Big Cry
 CSK Automotive
www.cskautomotive.co.uk
Post #196711 27th Dec 2012 4:20pm
Chris don't forget the rear door card. Just to add to your costs. Laughing TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #196715 27th Dec 2012 4:27pm
Chris, when you do your doors will you fix the Dynamat to the inside of the door skin or back of the door panel ?
Post #196719 27th Dec 2012 4:32pm
Killer90
Site Sponsor
Will be the door Skin mate, i cant see it making a difference on the door card itself Thumbs Up CSK Automotive
Post #196769 27th Dec 2012 6:27pm
adseybear
Canada
Good start to getting a bit of insulation down in the front?
http://www.exmoortrimshop.com/index.php?pa...p;Itemid=3 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #196882 28th Dec 2012 12:32am
barbel jim
Just wondered if anyone had Dynamated the robber Gbox tunnel ?? Looks possible, but still has a big whol;e in the middle, so would it be worth it, or would it funnel the noise up ??
Post #198318 2nd Jan 2013 8:35am
Killer90
Site Sponsor
its possible and when i get round to doing the front of mine im going to do it so will get some photos up Thumbs Up Thumbs Up CSK Automotive
Post #198442 2nd Jan 2013 6:14pm
I'd say it was still worth doing. Hole there or not. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #198456 2nd Jan 2013 6:43pm
barbel jim
It is quite hard, just a funny shape one side. Doing it all with Dynamat. In for a penny and all that. Managed to get a deal on the door kits, at my local ice. They have a load so keen to shift ! Going to try and do it matching the removable panels so as they can be removed if necessary without ripping it all up. Bought some ali tape to cover the joints.
Post #198487 2nd Jan 2013 8:09pm
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
Is it good stuff this dynamat,does it reduce noise much.
Post #200980 11th Jan 2013 9:56pm
I haven't got around to getting any / fitting any but I've heard nothing but positive comments and never seen a single bad comment about it. Just takes a bit of effort to fit as there is so much removal of trim ect to do first. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #200984 11th Jan 2013 10:13pm
barbel jim
Slowly getting there with the Dynamat- not finished yet, still the floors to do, but what a difference. I have a h/t 90 TD5, and have done all the rear panels to roof, wheel arches, bulkhead (both sides) and seat box so far. Still have the firewall and floors to go but already it is notably quieter !!! Very Happy Brought some rubber checker plate matting of flea bay and coated the dynamat on the bulkhead, and above the wheel arches. Have mud sides to go above. I have used 7 boxes (@ 12 sq ft) so far, so another 3 should see it finished. Think it will be the best £400 upgrade ever for a defender ! Very Happy
If your thinking about it , my advice would be do it !! Thumbs Up
Post #201751 14th Jan 2013 5:11pm
Mine has got gallons of the stuff in it, tonight driving home in the (some places flooded) roads, you can't even hear the water spraying up in the back. As said above, a good mod to do Thumbs Up
Post #201767 14th Jan 2013 6:10pm
