Home > In Car Electronics > Td5 90 CSW audio upgrade/soundproofing. |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 260 |
So confused reading through the massive thread, so I thought Id start my own.
Looking to slowly upgrade the audio in my 90, and need some advice. Currently I'm running the stock speakers under the dash, with a Sony headunit which I use to stream music from my iphone via bluetooth. Im useless with wiring, so will most likely need someone to do any of the more serious bits. Where should I start? Thoughts are a pair of rear speakers in some rear speaker panels, upgrade the under dash speakers and tweeters in the dash? Do I need an amp and should I upgrade my headunit? What speakers to go for, it seems these would be perfect for the front and rear? http://www.justkenwood.co.uk/car-audio.aspx/kfc-s1094-speakers Whenever I pull up any trim or carpet etc. I'll be looking to add some sound deadening too. First thing, ordering some of these: http://www.mudstuff.co.uk/Defender_Rear_Speaker_Panels.shtml 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
27th Dec 2012 3:44pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
As steve said Dynamat is the one, butt is costly, it cost me £130 to do the back of my 90 and i still got the sides, roof,door cards and front to do
Click image to enlarge Click image to enlarge CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
27th Dec 2012 4:20pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20441 |
Chris don't forget the rear door card. Just to add to your costs. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
27th Dec 2012 4:27pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Chris, when you do your doors will you fix the Dynamat to the inside of the door skin or back of the door panel ?
27th Dec 2012 4:32pm |
Will be the door Skin mate, i cant see it making a difference on the door card itself CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
27th Dec 2012 6:27pm |
Good start to getting a bit of insulation down in the front?
http://www.exmoortrimshop.com/index.php?pa...p;Itemid=3 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
28th Dec 2012 12:32am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
Just wondered if anyone had Dynamated the robber Gbox tunnel ?? Looks possible, but still has a big whol;e in the middle, so would it be worth it, or would it funnel the noise up ??
2nd Jan 2013 8:35am |
its possible and when i get round to doing the front of mine im going to do it so will get some photos up CSK Automotive
2nd Jan 2013 6:14pm |
I'd say it was still worth doing. Hole there or not. $W33T $0U7H3RN $UG4R
2nd Jan 2013 6:43pm |
It is quite hard, just a funny shape one side. Doing it all with Dynamat. In for a penny and all that. Managed to get a deal on the door kits, at my local ice. They have a load so keen to shift ! Going to try and do it matching the removable panels so as they can be removed if necessary without ripping it all up. Bought some ali tape to cover the joints.
2nd Jan 2013 8:09pm |
993porky Member Since: 01 May 2011 Location: sunderland Posts: 171 |
Is it good stuff this dynamat,does it reduce noise much.
11th Jan 2013 9:56pm |
I haven't got around to getting any / fitting any but I've heard nothing but positive comments and never seen a single bad comment about it. Just takes a bit of effort to fit as there is so much removal of trim ect to do first. $W33T $0U7H3RN $UG4R
11th Jan 2013 10:13pm |
Slowly getting there with the Dynamat- not finished yet, still the floors to do, but what a difference. I have a h/t 90 TD5, and have done all the rear panels to roof, wheel arches, bulkhead (both sides) and seat box so far. Still have the firewall and floors to go but already it is notably quieter !!! Brought some rubber checker plate matting of flea bay and coated the dynamat on the bulkhead, and above the wheel arches. Have mud sides to go above. I have used 7 boxes (@ 12 sq ft) so far, so another 3 should see it finished. Think it will be the best £400 upgrade ever for a defender !
If your thinking about it , my advice would be do it !! |
14th Jan 2013 5:11pm |
Mine has got gallons of the stuff in it, tonight driving home in the (some places flooded) roads, you can't even hear the water spraying up in the back. As said above, a good mod to do
14th Jan 2013 6:10pm |
