Home > Td5 > td5 ecus
Page 2 of 2 <12
laralandy
Does anyone know how to find the ecu number? my ecu hase no stickers on it atall!! Is it woth buying an msb ecu from here http://www.ebay.co.uk/itm/Land-Rover-Disco...1e74f60e7d He seems to suggest plug and play. Want to also order some form of diagnostics for the abs tc problems but if the ecu is disco not defender then i guess the diagnostics wont read properly.
Sorry for all the questions. I hope one day to be able to provide others with help, untill then i will sit in the corner with me dunce cap on!!
Post #196162 24th Dec 2012 9:21am
bob neville
Have you unbolted the ECU and looked underneath, quite often the stickers are hidden there.
The sticker on mine is actually on the top and it is just readable !
I would guess that if there are no identifying numbers then you will need to get it on diags to find out.
2013 Defender 90 CSW - sold
Post #196169 24th Dec 2012 10:02am
laralandy
AHA! i have an invoice for tamar electrics to decode an defender ecu with the number A0016-MSB000080-0801000080. Does that mean anything??? Confused
Post #196216 24th Dec 2012 1:59pm
Porny
Site Sponsor
MSB0000080 is an early Td5 Defender ECU.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #196224 24th Dec 2012 2:46pm
laralandy
Thanks for all the help. I have ordered an msb ecu from ebay. Its supposed to be straight plug and play. Ill let everyone no how i get on with it. It is also chipped for more power. Fingers crossed
Post #196871 28th Dec 2012 12:29am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I'm sure it will still need to be paired with your AS10 in order to start.
Post #196909 28th Dec 2012 10:37am
Yup.
Post #196915 28th Dec 2012 11:08am
laralandy
well i said i would let you no how it went. Ecu turned up, plugged it in and all is well!! i now have a normal temp guage and also the fuel guage seems to work. Quit a Loss in power though but so much smoother to drive. it was so jerky before almost impossible to drive at lower speeds in low gears. Just did a varied 30mile drive and al is good. So it is indeed plug and play for others who want to no. thanks again for all the help. Now to sort out my asb tc intermittent fault. Time for a hawkeye me thinks.
Post #197049 28th Dec 2012 8:10pm
me@td5.org
Does your alarm work?
Post #197125 28th Dec 2012 11:56pm
laralandy
To be honest I don't think the alarm worked when I bought it so I can't really say but probably not.
I do wish I went for the nnn ecu he was selling as I miss the grunt that my old ecu gave me. Faint oil in the loom aswell so I'm going to try the method of filling the plug with grease so the oil cannot pass into the ECU. Oh land rovers' so much to do to them so little time!!
Post #197171 29th Dec 2012 9:39am
Page 2 of 2 <12
