Home > Td5 > td5 ecus
laralandy
td5 ecus
hi, ive just bought a td5 90 2001 x tech and it has a few things to fix before its 100% right, one thing is that i believe it has a disco ecu and maybe disco injector harness. Im led to believe this can cause a few problems one of which is a crazy temp guage?? if so how is this solved?? where can i get a proper ecu for my defender? how do i no which is the proper one?? Also would this cause an abs and tc light on problem. no the 3 lights just tc and abs.
the engine runs fine and pulls like well. all i really know is tdi,s. so excuse my ignorance one the td5s
Any help much appreciated
Post #195042 19th Dec 2012 10:00pm
Martin
Site Admin
Is the temperature gauge crazy I suppose is the first question?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #195043 19th Dec 2012 10:01pm
laralandy
Lol yeah temp guage problem one. Abs tc not really a problem till the mot in 12months. im told its an intermittent fault which i believe to be true as i guess it would have failed on mot if it was on all the time. unless its possible to remove the warning bulbs!!
Post #195044 19th Dec 2012 10:05pm
davew
If the ECU is the later NNN type it can be reprogrammed from a Disco to Defender. http://www.yorkshireoffroadclub.net/
Post #195062 20th Dec 2012 12:17am
landy andy
Did not think a 2001 X-Tech had ABS and TC. Question
Andy
Post #195066 20th Dec 2012 3:06am
laralandy
hmmmmm. interesting. The lights are illuminated though. Unless this is the defender ecu causing it to think it has abs traction control etc?? Will the injector wiring harness really cause this problem or just the ecu? A chap on the dreaded bay is selling nnn or msb (what ever these are) ecus saying they are plug and play?? is that correct?
Post #195070 20th Dec 2012 6:19am
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Thought ABS & TC was an option on all TD5s look for the wire sensors on the inside of the wheels.
Post #195071 20th Dec 2012 6:45am
laralandy
yeah it does have abs, i can see from the servo. So is there anyway to get a defender temp guage to work with a discovery ecu??
Post #195185 20th Dec 2012 6:57pm
davew
Why ask a question if you're not reading the answers ? http://www.yorkshireoffroadclub.net/
Post #195203 20th Dec 2012 7:55pm
laralandy
ah sorry about that, im using my phone and its useless, i didnt see the answer. Ok well i will have to try get it reprogrammed or plump up the cash for the ecu on ebay which is supposed to be plug and play and include a power remap. 395 for the msb or 495 for nnn. whatever that means.
cheers all
Post #195227 20th Dec 2012 8:56pm
landy andy
MSB and NNN are the two types of ECU.
MSB are the older ones that can not be reprogrammed they physically have to have a chip removed and new one soldered in.
NNN are the later ones that can be reprogrammed
Andy
Post #195230 20th Dec 2012 9:06pm
davew
If you look on the ECU there should be a part number, if it starts NNN such as NNN000120 then it can be reprogrammed as a Defender ECU. If it starts MSB then it can't be changed from one to the other as far as I am aware.
Any Land Rover specialist should be able to change it over for you if it's an NNN type, shouldn't cost much as it only takes a few minutes with an Autologic or similar unit. I got two done in around 20 minutes including putting in the injector codes and training them to the immobiliser.
The ECUs come up on ebay regularly, you can usually get them for under £200.
This one for example...
http://www.ebay.co.uk/itm/140898897603
I'm sure one of the forum sponsors will be able to help either way.
Given the odd history it would be worth checking the injector codes on the engine actually match those in the ECU. You just have to take the rocker cover off the top of the engine and make a note of them (printed on the top of each injector). http://www.yorkshireoffroadclub.net/
Post #195232 20th Dec 2012 9:07pm
wslr
You can't programme a Discovery ECU to a Defender one.
Post #195324 21st Dec 2012 10:32am
Porny
Site Sponsor
Yes you can...
Apart from NNN000250 as there is technically no Defender map - as that ECU is unique to a Disco.
Any NNN500020 or NNN000120 can be 'reflashed' to a Defender or Disco.
As a bit of bodge, you can convert a MSB none flash as wel..
With a Disco Cal on a Defender the temp gauge will work the wrong way round.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #195327 21st Dec 2012 10:39am
landyman37
Ian
If I used a discovery ecu you say the temp gauge works backwards.
Maybe that is what I need then.
Phil
Post #195887 22nd Dec 2012 10:03pm
