Home > Puma (Tdci) > Turbo hose gets blown off
A�ron
Spain
Yesterday i was driving 100 km/h and for the second time in 8 weeks time the turbo hose got blown off the engine.
I put it back on and the engine was in limp mode.
After restarting the engine everything is fine again.
It is a 2.2 from january with 2500 km.
I thought there was something of a recall from that hose....
Can someone tell me something over the possible reason the tube is getting off the turbo?
Thanks!
Post #195552 21st Dec 2012 10:43pm
rover
I had the same problem with my 2.2. Took it back to the dealer, they said that LR knew about the problem, a new hose was fitted that the dealer said was slightly different design, I can not see any difference myself, but no problems since.
Post #195687 22nd Dec 2012 3:51pm
A�ron
Spain
Thanks!
I am going to the dealer at the 26-12 and the order a new hose for me.
Post #195775 22nd Dec 2012 8:01pm
ZeDefender
So you've decided then Laughing Tell someone you love them today because life is short.
Post #195845 22nd Dec 2012 10:10pm
A�ron
Spain
i am not sure yet Shocked
Post #195926 23rd Dec 2012 9:40am
ZeDefender
Sorry - that was a response to the four identical posts - where d'they go? Tell someone you love them today because life is short.
Post #195935 23rd Dec 2012 10:25am
A�ron
Spain
the engine light turned itself off.
I didn't know it can reset itself.
Post #196076 23rd Dec 2012 7:40pm
Firefly
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Baltic Blue
I have a 2013 MY Defender with just 1100 miles covered; this model is supposed to have the latest and greatest fix to this problem but yesterday off came the turbo hose! I limped along managing just 40mph at times on a rush hour A14 - not too funny! It now needs a new hose as following the failure the hose was abraded by the alternator pulley.
Land Rover Assistance guy (excellent service by the way) suggested that the hose was not installed correctly but I don't have too much confidence, I think I will get some Mikalo hose clamps to replace the factory fit jubilee style clips on the turbo hoses.
This is really not rocket science and should have been fixed by now, seems like Land Rover are using their customers to test their vehicles, a good old Lotus technique!
I had none of these problems with my 2009 2.4 TDCi over 50K miles
Post #198869 4th Jan 2013 12:52pm
ericvv
Post #198871 4th Jan 2013 12:55pm
Firefly
ericv, Looks like a good piece of kit, I think the 2.2 and 2.4 are slightly different hence the bulk of the problems being with the 2.2, so correct fitment would have to be confirmed.
For some faults the warning light is supposed to extinguish after 4 ignition cycles once the fault is no longer present.
Post #198878 4th Jan 2013 1:19pm
jst
ericvv wrote:
Would this be a possible definite solution?
http://www.entreq.de/products/performance/...r-td4.html
how much!? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #198911 4th Jan 2013 3:20pm
A�ron
Spain
The dealer replaced the tube between the turbo and intercooler for a tube with a totally different design and the problem is solved.
If you still have the hard plastic tube between the turbo and intercooler get it replaced by the modify part.
Post #198926 4th Jan 2013 4:53pm
