Home > Maintenance & Modifications > Moving the Alarm and adding a BBUS on a TD5
Tiger
So I have now completed a full removal and relocation of the standard alarm and I've added a BBUS (Battery Back Up Sounder).
I'd recommend doing this and it's not too hard if a little time consuming.
Happy to do a full post with instructions on how to do it. Good or bad idea for obvious reasons ????
Post #194863 19th Dec 2012 10:34am
Publicising the changes you've made probably defeats the object to be honest, but I'd be interested to know how much the BBUS kit was and where you got it from? Darren
Post #194869 19th Dec 2012 11:10am
Tiger
Okay I reckon a general pointer can't hurt.
On a TD5 have a look at the alarm loom and if you have a plug that looks like this (brown one) you can add BBUS.
Mine was just plug 'n play
The BBUS looks like this.
I got mine from Dan @ Duckworths it was LR014059 and cost £76+VAT and that is all I needed.
For the normal sounder I moved this by tracing back the wires to the large multiplug attached to the heater box and then spliced a new loom in and then I've hidden it.
For the BBUS I extended but you can trace back and splice in if needed (need to be careful though as the four wires are unmarked and just black and if you get them wrong it will go off and it's fecking loud and unplugging it doesn't stop it!!! Whistle )
The location of both alarms are disparate, very awkward and secret Thumbs Up
Post #194880 19th Dec 2012 11:48am
Tiger
Also, worth checking your bonnet alarm switch.
Mine was 'lazy' and would have triggered the alarm should the bonnet be lifted.
I removed, cleaned, WD40'd and now it works as it should. Thumbs Up
Post #194884 19th Dec 2012 11:58am
DAZ110
If you haven't got the wiring already there on the defender for the BBUS you will need to buy and fit a wiring harness part number: YMD001020 which is also available from Duckworths (Approx. £115.00). This harness connects to the main loom plug in the corner of the bulkhead and has all the connections on the other end for the BBUS and headlight, indicator, sidelight, horn, etc
Post #194898 19th Dec 2012 1:04pm
Excellent, I should have realised that Dan would be the man to go to. Thanks very much Thumbs Up Darren
Post #194906 19th Dec 2012 2:00pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
According to the MG rover forum the sounder is actually a BMW item part number 65758383153
Jason.
Post #194932 19th Dec 2012 4:11pm
Lorryman100
Good job Thumbs Up
Post #194935 19th Dec 2012 4:21pm
Tiger
Jason.
Throw that part number into google and it shows a very different looking part, I'd reccomend playing it safe and getting it from a LR dealer Thumbs Up
Post #194936 19th Dec 2012 4:23pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
I'm convinced that these LR014059 BBUS alarms are the same as the second hand ones on Ebay which appear to quote part AMR4974 or AMR 4971.... Only risk there of course is how good the Nicad battery will be at holding its charge on a second hand one.
Not really worth the risk IMHO, so best to buy new but factor in a need to test how it holds its charge every now and then and replacing it at some point.
What's really frustrating is those part no's above are seen from P38 Rangies and Tdi Discos. I'm making a big assumption that they were standard fit, but if so, LR had the kit, and seem to have standard wired the Td5 for the BBUS and then penny pinched and didn't fit one as standard.... Makes you wonder if perhaps a few less could have been nicked Shocked Jon - 110 td5 [sold]. Currently Defenderless.
Post #194953 19th Dec 2012 5:42pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Wonder if the harness for BBS is there on all Pumas....? Anyone know for sure. Too cold and wet for me to go and have a look
Post #195039 19th Dec 2012 9:42pm
DAZ110
Mine didn't have the BBUS plug Sad ....so I had to buy the harness.
My Defender is an 07 XS SW 110 Puma in case that matters?
Post #195086 20th Dec 2012 8:45am
kmac
Hi - what is the harness part number please and where did you get it from? - Sorry scratch that just saw your earlier post. Wll check if mine has it (fingers crossed)
- Does double the cost though if you need to buy that Big Cry
Post #195087 20th Dec 2012 8:54am
DAZ110
Yes, more money for the harness but might be better than loosing your Defender. Big Cry
Actually I think the total cost of the harness was £113.80 from Dan at Duckworth's and the BBUS was £96.00
....But as the saying goes: Prevention is better than cure !Thumbs Up
Post #195090 20th Dec 2012 9:06am
Tiger
If somebody can find the plug (it's quite unique though) then I'm happy to trace back to the big multiplug on the side of the heater box and do a wiring diagram. I wouldn't suggest just loose pins; if one came off it would be a *loud* fix.
The extra loom as I understand is the same as what is there plus 4 wires and the plug for the BBUS.
The 4 wires to the BBUS are Perm+ / Perm- / Signal 1 / Signal 2.
Ironically you don't want to put the BBUS in the front wing anyway, so you might end up buying the loom and chopping the BBUS wires out.
So if anybody can source the multiplug I'm happy to do instructions to wire to the existing big block on the heater box.
Post #195093 20th Dec 2012 9:16am
