Home > Td5 > Tuning / chipping my TD5 ..
Page 2 of 2 <12
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
thanks for the info people Thumbs Up but is the turbo the only way of getting more torque at lower rev's ... Embarassed Postmanpat
Post #194793 18th Dec 2012 10:22pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
A good remap, increased and an upgraded intercooler will give you more power and torque throughout the rev range but don't expect there to be flat torque curve.
The turbo needs exhaust pressure to spin, the fixed geometry is a compromise it doesn't create enough boost at low revs and produces too much at high revs so is waste gated.
The TT S208 which is sold by Pete and Ian addresses this and addresses this. I have always been very happy with the performance of these but the reliability of the Turbo has been an issue.
There are 2 other models listed by TT the S208-1 which has a lower pressure output and the S220 which is a larger hybrid unit.
Aside from TT there are units by Owen Developments retailed by Alive tuning as the Larger Charger which is a hybrid Wategate turbo.
Post #194799 18th Dec 2012 10:33pm
JWL
My turbo is still original and I would put the extra torque on mine down to the decat, middle box out and mainly on the remap. Towing right on the 3.5t limit(2.7t mini digger on plant trailer plus buckets and mud) mine towed it well. A standing start on an incline was better in low range but level pull aways at junctions was comfortable in high box. I felt it towed that set up as well as it towed the same type of trailer empty with no remap.
When it was remapped the MAF had to be renewed(surprise surprise) and it hadn't seen anyone to upgrade odd things on the electrickery bits since it left the factory 6 years previously even though it was supposed to have dealer servicing. It is ex-police and they sent it to a main stealer once a year for the main services, I doubt whether it actually saw the inside of the workshops at the dealers, it's not like your own motor where as the driver/owner you'd notice!
Post #194802 18th Dec 2012 10:45pm
Postmanpat
understood how it works re the turbo Wink If I understand you correctly you have the TT S208 fitted , major difference ??? What you mean re " the reliability of the Turbo has been an issue. " ? Thanks PP Postmanpat
Post #194875 19th Dec 2012 11:27am
Postmanpat
thanks for your reply , I have changed to the decat and removed the middle box plus installed a large intercooler so I'm now looking at what mapping is the best to go for re performance and reliability in the long run . So any specific info re the mapping would be appriciated ... Bow down Postmanpat
Post #194876 19th Dec 2012 11:30am
bell-auto-services
Regarding turbo reliability, on the over 100 units i have sold i have only ever had 1 failed unit. This was infact due to a map that was already on the car that was not working correctly as well as the customer who decided to change the actuator postion as they thought increasing the vane angle would help Confused
All out turbos come with 1 years TT warranty on faulty parts.
Pete
Post #194879 19th Dec 2012 11:44am
Postmanpat
Pete
ok , so what package would you advice me to get ? if you like pm me or I can sent you my email ... Wink Postmanpat
Post #194881 19th Dec 2012 11:48am
bell-auto-services
I think all you have left to modify is a remap and turbo.
Pete
Post #194882 19th Dec 2012 11:50am
Postmanpat
Pete
thanks but which remap , so many out there ... and which type of turbo ... Postmanpat
Post #194883 19th Dec 2012 11:53am
bell-auto-services
Im biased Very Happy
BAS remap and BAS TD5 VNT Razz
Pete
Post #194887 19th Dec 2012 12:07pm
Postmanpat
Pete
don't wanna come across being tick , but where do i find info re same ... Wink Postmanpat
Post #194888 19th Dec 2012 12:15pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
You have three choices...
1. Go for stage II remap and stick with that.
2. Do a deal with one of the suppliers that you go for stage II remap to try it out. If ok stick, if you want more go back and get a VGT turbo with a corresponding remap and they only charge for one remap and labour to do 2nd remap.
3. Go straight to VGT turbo and remap to suit.
As for where, you've already been recommended two of the best, but you can try others.
Oh there's a 4th choice, do nothing Wink Wink Wink
Steve
Post #194889 19th Dec 2012 12:15pm
Postmanpat
Steve
Smile say will look at choices 2 or 3 , thanks Thumbs Up Postmanpat
Post #194891 19th Dec 2012 12:20pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
just email BAS and get it over and done with he might get it to you for xmas Thumbs Up
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #194904 19th Dec 2012 1:30pm
me@td5.org
Pete
My first problem was leakage around the turbine housing. Exactly the same as experienced by this person:
The second has been a failure of the vanes (with no change in the position of the actuator)
However the 1 year warranty has covered.
I guess I must have been unlucky if you have had only 100:1 with a problem.
Post #194959 19th Dec 2012 6:10pm
Page 2 of 2 <12
