![]() | Home > Td5 > Tuning / chipping my TD5 .. |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 ![]() ![]() ![]() |
Dear All ,
have a 2004 110 TD5 ( 75.000 miles on the clock ) , until today I have only fitted a bigger intercooler and removed the middle box and was more then happy with the performance . Now I modified my Defender 90 to a pure off-roader and have started pulling it behing the 110 to events , but find I could do with more power ie more torque . Would appreciate your input / views / feedback as I'm sure many of you around here have done upgrades in the past and by now have plenty experience ... Kind regards PP Postmanpat |
thanks Steve , have replaced the cat with a straight through section and removed EGR .
Re the turbo's , have read about them etc but wonder is it worth the money / effect on the life time off the engine and more important I'm looking for more torque at the lowest possible rev's so don't think the turbo is the way to go . But again open to corrected on that one ... Postmanpat |
I wouldn't have thought the intercooler is particularly effective on a slow moving off roader ?
I'm not sure there is a lot you can do in terms of improving low down torque for slow speed work (beyond the obvious that you've already done) which is why challenge vehicles tend to go for capacity with big V8's and the like ![]() |
indeed the intercooler isn't effective when slow moving , only at higher speeds . And a V8 etc I don't even consider , want to keep the TD5 and I know plenty options are out there to improve it just wondering which are the best ie most effective ![]() |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 ![]() ![]() |
The upgraded turbo that Ian uses, IIRC, is a VGT turbo giving higher boost at lower revs than standard, so you will see an improvement in torque at lower speeds. I'm sure Ian can provide rolling road graphs etc to show you real data. Cheers Steve |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
give BAS a call or drop him an email he is one of the well known site sponsors he will sort you out with what you need just tell him what youve got i got my disco 2 td5 done by him ?
how old is the car you may need to send him the ecu for it to be done ? but he will look after you on price ![]() steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Thanks Steve , sounds really interesting and indeed would be nice if he could provide same ![]() where would be the best place to sourse same ? Postmanpat |
thanks will do ... ![]() |
Putting a remap on your towing motor will transform it, mine was remapped 3 years ago and makes the thing so much more user friendly. I've just got a stage 1 on mine, the cat and centre box I only took off this year and I tow all sorts of trailers. When I had a big caravan, on the motorway you just got into 5th and never changed gear untill you left the motorway. Explain what you want to do with your motor and a good tuner will tailor the tune to your needs.
thanks JWl , fair to ask what remap you used ... Postmanpat |
pete at BAS can also supply the same turbo if you wanted one ?
as i said give him call or email steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
My remap was done by J E Engineering in Coventry, mainly because they had a deal on at the time and I could justify the 150mile round trip with visiting relatives. Yes OK having a good run out on the way back did give a bit more incentive
Website is here http://www.irbdevelopments.com/ with contact details. If I recall, Ian and Pete at BAS co-developed the turbo together. Ian is very knowledgeable, and he's ex LR and now has his own 4wheel rolling road. Expensive to travel over, but if you want to go down this route it's probably worthwhile travelling over to have it done properly. Cheers Steve |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
I can agree Ian and my self jointly did the TD5 vnt turbo amongst others though I developed my self the tuning for it and do supply it to Ian on a dealer distributor basis so no matter where you buy it will be the same unit if you select a new turbo upgrade, The dyno he uses however is one of the same dynos I use sometimes at http://www.viezu.com/ of which is in Bromsgrove. We also use a Dyno Dynamics Dyno a little nearer to us in Leeds amongst others.
Pete |
