Home > Td5 > Tuning / chipping my TD5 .. |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 |
thanks for the info people but is the turbo the only way of getting more torque at lower rev's ... Postmanpat
18th Dec 2012 10:22pm |
My turbo is still original and I would put the extra torque on mine down to the decat, middle box out and mainly on the remap. Towing right on the 3.5t limit(2.7t mini digger on plant trailer plus buckets and mud) mine towed it well. A standing start on an incline was better in low range but level pull aways at junctions was comfortable in high box. I felt it towed that set up as well as it towed the same type of trailer empty with no remap.
When it was remapped the MAF had to be renewed(surprise surprise) and it hadn't seen anyone to upgrade odd things on the electrickery bits since it left the factory 6 years previously even though it was supposed to have dealer servicing. It is ex-police and they sent it to a main stealer once a year for the main services, I doubt whether it actually saw the inside of the workshops at the dealers, it's not like your own motor where as the driver/owner you'd notice! |
18th Dec 2012 10:45pm |
understood how it works re the turbo If I understand you correctly you have the TT S208 fitted , major difference ??? What you mean re " the reliability of the Turbo has been an issue. " ? Thanks PP Postmanpat |
19th Dec 2012 11:27am |
thanks for your reply , I have changed to the decat and removed the middle box plus installed a large intercooler so I'm now looking at what mapping is the best to go for re performance and reliability in the long run . So any specific info re the mapping would be appriciated ... Postmanpat |
19th Dec 2012 11:30am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Regarding turbo reliability, on the over 100 units i have sold i have only ever had 1 failed unit. This was infact due to a map that was already on the car that was not working correctly as well as the customer who decided to change the actuator postion as they thought increasing the vane angle would help
All out turbos come with 1 years TT warranty on faulty parts. Pete |
19th Dec 2012 11:44am |
ok , so what package would you advice me to get ? if you like pm me or I can sent you my email ... Postmanpat |
19th Dec 2012 11:48am |
I think all you have left to modify is a remap and turbo.
Pete |
19th Dec 2012 11:50am |
thanks but which remap , so many out there ... and which type of turbo ... Postmanpat |
19th Dec 2012 11:53am |
Im biased
BAS remap and BAS TD5 VNT Pete |
19th Dec 2012 12:07pm |
don't wanna come across being tick , but where do i find info re same ... Postmanpat |
19th Dec 2012 12:15pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 659 |
You have three choices...
1. Go for stage II remap and stick with that. 2. Do a deal with one of the suppliers that you go for stage II remap to try it out. If ok stick, if you want more go back and get a VGT turbo with a corresponding remap and they only charge for one remap and labour to do 2nd remap. 3. Go straight to VGT turbo and remap to suit. As for where, you've already been recommended two of the best, but you can try others. Oh there's a 4th choice, do nothing Cheers Steve |
say will look at choices 2 or 3 , thanks Postmanpat |
19th Dec 2012 12:20pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
just email BAS and get it over and done with he might get it to you for xmas
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
19th Dec 2012 1:30pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
My first problem was leakage around the turbine housing. Exactly the same as experienced by this person: The second has been a failure of the vanes (with no change in the position of the actuator) However the 1 year warranty has covered. I guess I must have been unlucky if you have had only 100:1 with a problem. |
19th Dec 2012 6:10pm |
