![]() | Home > Maintenance & Modifications > Fitting a, X Defend -Column ignition barrel shield to a Puma |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 ![]() ![]() |
Excellent write up. Well done.
Is the 'chip' that the coil picks up in the remote fob or key ? |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
It is in the fob.
In which case it's unlikely there will be an issue with the transducer coil as LR would have to bear in mind that the fob hangs from a key ring and is constantly 'swinging'. I would presume the range is probably 4" plus
It is a lot more than 4"! I decided not to shear the bolt just yet, as I know from experience how temperamental the 10AS can be and for the sake of a few test runs carried out over a week or two, makes it worth the wait in my opinion. ![]() |
Thanks Brian....
![]() Exactly what is needed for when I receive mine hopefully Monday/Tuesday. A clear and concise write up with pictures. ![]() Treat every day as if it is your last....one day you will be right!! |
good write up Brian
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Might not work then with one of dgardel's group buy keys then
Great report Brian!!!!
![]() ![]() ![]() ![]() ![]() IID Pro MV License |
You could always measure the integrated key/fob? My LR key is 45mm from the tip of the key to the start of the plastic handle at the middle, as it is slightly rounded. ![]() Click image to enlarge Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
Brian,
Excellent write-up ![]() Purchasing mine now for fitting over Christmas. Cheers, Superspoons |
Thanks Brian - feeling more confident now
![]() But shout it at them in German because life is also terrifying and confusing... |
Well I have just been for a run lasting 40 mins over the roughest roads and tracks with no immobilizer issues. The fact that the Puma started when I first tested the set up was enough really but I advocate testing things thoroughly before saying that is it working.
![]() As a further precaution I plugged in a diagnostic tool to have a look at the events log in the 10AS and nothing was logged. So all in all it is looking good to mounting the coil under the shield with no apparent drawbacks as of yet. I will keep checking things over the next week or two but I am not expecting any issues. ![]() I think I will have to take off the top cowl again to see if I can't get the join fitting better at the ignition. Even though I can't see it when driving, the fact I know it is there is really starting to bug me. ![]() Brian. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Cracking write up (as always).
Just as some input. My keys and Fob are separated by a keyring by 15cm. I tend to let the fob hang low and never had a problem in over 3 years- I am sure you won't have any problems with it ![]() Glyn ![]() ![]() |
