Home > Maintenance & Modifications > Fitting a, X Defend -Column ignition barrel shield to a Puma
Page 2 of 4 <1234>
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
That's very comprehensive. Thank you. Going to get one in the new year.
Post #194120 16th Dec 2012 8:58pm
Lorryman100
I meant to say in the post that you shouldn't poke about the coil or touch the copper windings with the ignition in the on position, unless you want to taze yourself (50,000 volts) that is? Whistle
Post #194121 16th Dec 2012 8:58pm
SimonR
Thanks for posting the instructions. I've had many questions about fitting them to Pumas and you have answered all of them!
I don't think you are going to see 50kV in the coil though - much closer to 12v I suspect!
I originally intended to fit the coil there, but on my Td5, just couldn't get it to fit nicely. That it fits there on a Puma is more ideal.
The blue bit is only really intended to cover up any 'bodgery' in enlarging the hole in the cowl. It doesn't need to be done up tight. Loosening it a little should help the two halves meet up better.
Thanks again,
Si
Post #194131 16th Dec 2012 9:31pm
Lorryman100
Yes, the input voltage will only be about 12v but with the induction coil this voltage is multiplied by the cycles around the copper coil windings ( think of the old coil in a petrol engine, 12volts in but enough out to light a spark plug). Then again you can always put a multimeter on the coil (the copper windings and not the input plug) with the ignition on, then when you need to buy a new meter, you can trust me when I say you won't be making that mistake again. Whistle
Don't ask me how I found this out. Embarassed
Post #194157 16th Dec 2012 10:07pm
kmac
Your multimeter not fused then?
Post #194248 17th Dec 2012 10:51am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Found out, sat in a puddle of wee, with hair on fire and fingers smouldering.
Post #194254 17th Dec 2012 11:03am
Tiger
Just a side point, but I thought the coil was just there to 'agitate the fob' in to sending a radio signal that told the alarm to disable the immobiliser and once the fob has sent the signal to the alarm and the ignition is on then the immobiliser wont re-engage until 30 seconds after the ignition has been switched of. It's continued proximity the steering column is irrelevant?
Way to test this:
Test 1:
Open the car with the fob, don't have it on the keyring and don't put it anywhere near the steering column, start the car within 30 seconds of opening
Expected Result 1:
Car should start
Test 2:
Open the car with the fob, don't have it on the keyring and don't put it anywhere near the steering column, wait for more than 30 seconds then try to start car
Expected Result 2:
Car wont start
Test 3:
Open the car with the fob, don't have it on the keyring and don't put it anywhere near the steering column, wait for more than 30 seconds then try to start car, car shouldn't start, then keeping the plip away from the steering column plip the unlock
Expected Result 3:
Car should start
Post #194258 17th Dec 2012 11:22am
Lorryman100
The pulsed feed from the 10AS module causes the magnetic field created by the transceiver coil to collapse and restore. The fluctuating magnetic field activates the fob (remote RF handset) to transmit a mobilization code to the 10AS module. The 10AS module receives the fob mobilization code via its antenna. This fob code is compared to a value in the 10AS memory. If the codes match, the 10AS module provides a mobilization signal to the instrument cluster. The instrument cluster acts as a gateway, converting the signal transmitted from the 10AS module into a signal that is recognizable by the ECM. The passive immobiliser works by switching on the immobiliser after a set time once the key/fob is removed. It detects this by using the transceiver coil on the ignition barrel to detect the key/fob. If there is no fob to generate the signal for the 10AS to pick up then it will act as if the key/fob is removed by initiating the immobiliser after 5 mins which will stop the engine by inhibiting the starter and fuel injector circuits via the EMS. There is a way around the passive immobilizer in the EKA code. Entering the EKA code disables the passive immobilizer for one ignition cycle. There have been a few members on here with passive immobilizer issues due to problems with one or more parts of the 10AS system, off the top of my head, Merlin's issue comes to mind?
This is the settings page for the 10AS and shows the info on the fobs. This is a blank one as I am not prepared in showing the settings of my Puma on a open forum.
@kmac, I think it blew it and arced across the gap causing the DMM to give up the ghost. Good news for me though, as it meant I could get the new fluke one that I really wanted in the first place. Thumbs Up
Brian.
Post #194314 17th Dec 2012 4:47pm
Lorryman100
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #194315 17th Dec 2012 4:48pm
SimonR
You will be pleased to know that it doesn't cause either a Fluke 79 nor a Fluke ScopeMeter to let the smoke out!
Si
Post #194335 17th Dec 2012 5:35pm
I have heard apocryphal tales of the coil/fob arrangement working with the fob left in the centre cubby, and even in a briefcase on the back seat (these tales were from a Landrover tech at a major and reputable dealer). So under favourable conditions at least I doubt range is an issue.
I am surprised that removal of the fob from range (or presumably the death of the fob battery?) could actually cause a running engine to stop, which it will do if my reading of the above posts is correct. I thought it was illegal for any anti-theft system to bring a car to an unexpected standstill for reasons of "safety", this being the reason that the Mechlok hydraulic lock is only approved for use on clutch lines not brake lines.
If this is the case then it is tough luck for a lot of people if you happen to be on a level crossing when the immobiliser shuts your engine off!
It was my understanding that once the start-up dialogue between the key/fob system and the immob system had successfully been carried out, the immob stayed off (ie engine running) as long as the ignition switch stayed in the engine running position, so even if you were to remove the fob completely from the vehicle once the engine was running it would stay running. You wouldn't be able to restart however once it was switched off.
Post #194583 18th Dec 2012 10:48am
SimonR
I've found that if the fob has a new battery, the coil will detect the fob over a range of about 1m. When the battery is getting flat, this reduces eventually to the point where it does not work at all!
Si
Post #194587 18th Dec 2012 11:08am
Lorryman100
I have one of these and they are worth every penny as it allows you to check that the coil and the fob are transmitting. It also highlights any intermittent issues with the immobilizer as well and it fits nicely on the shelf under the ignition.
http://www.hickleys.com/diagnostics/ad30.php
The way the 10AS passive immobilizer works is not a secret as it has been around since the mid 90's. A google search will, I'm sure tell you absolutely everything you need to know or list any details that you may want to check as does the workshop manual. You can also use your own diagnostic gear to investigate how the system works and see what is enabled in the settings menus, this is by far the best way to understand how the system works and how it is integrated into the IPAC and EMS, as you can do some trial and error testing to see the different results/options available. Thumbs Up
Post #194702 18th Dec 2012 7:32pm
Lorryman100
@ blackwolf http://www.defender2.net/forum/topic8577.html Thumbs Up
Merlin wrote:
Good news, the Defender has been repaired! Seems that the Lucas AS10 immobiliser was at fault, as several of the terminals were corroded as the result of water damage. These have been cleaned and the fault has gone. It appears that the AS10 ‘pings’ the key fob and it wasn’t getting these signals back and hence was shutting down the engine, via the EMS. I imagine that the water has been creeping in from somewhere around the windscreen as I have had a pool in the foot well since new. The stealership has limited this flow but it’s still there.
I’d like to especially thank Lorryman100 for all the help he has given. He said that he thought it was an electrical problem from the start and that the AS10 was probably to blame. And it was!
The garage in Llandovery, New Road Garage, were great although they had to go through a learning curve on the Puma engine. I would recommend them for repairs if you are in the area. They changed several bits that needed attention and hence I’m expecting a better performance now.
Thanks to all who contributed to this thread.
Merlin
Post #194710 18th Dec 2012 7:51pm
K9F
Hunk of metal arrived in post this morning (that'll be my MPG reduced yet again Laughing )....All I need now is some fair weather and a spare bit of time to fit..... Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #195334 21st Dec 2012 1:01pm
Page 2 of 4 <1234>
