Home > Puma (Tdci) > Clunky gearbox on 2009 Puma?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all,
Here I am, a new Defender owner with my first "proper" technical question... first of many to be sure! Laughing
Anyway... I find that no matter how careful I am while shifting, I still get a "clunk" in almost every gear while setting off. It is especially noticeable in 1st to 2nd, 2nd to 3rd and tapers off from 3rd to 4th.
I've tried variations of letting off the clutch and giving it more accelerator, more aggressive shifting, gentler shifting... the only way I've been able to get by is to to be super delicate with the clutch and accelerator, practically a ballet move, in order to get smoothly out of 1st. Not being a mechanic, I can only opine that it sounds like there is some kind of play or backlash.
To add to the above... going from 2nd to 3rd is almost always sloppy, in the sense that the meshing of the gears isn't so smooth.
So... do those of you with more experience driving and fixing TDCi have an opinion if it is something to be checked out, or could it be just a matter of refining my gearbox technique?
Post #19364 3rd Dec 2009 8:18am
AndrewS
Get a couple of 9/16th spanners and check the propshaft nuts/bolts. The nuts at the front of the rear prop are the worst culprits.
Post #19365 3rd Dec 2009 8:27am
eutek
Thanks for the advice!
Post #19366 3rd Dec 2009 8:58am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Yup - propshaft bolts are most likely. I have to tighten mine periodically. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #19367 3rd Dec 2009 9:04am
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
Could you please post a picture to show what you are talking about?
Thanks! Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #19400 3rd Dec 2009 5:31pm
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Hi Eutec,
I have exactly the same problems with gearbox/clutch "clunk" and "notchy" gear change on my 57reg Puma CSW. Its been in and out of the dealer a few times and they say they can find nothing wrong. I can minimise the "clunk" if I slightly rev the engine prior catching the clutch, but as you say it's a bit of a delicate operation.
As I have approximately 1 year of the warranty to go I have decided to give it another 6 months before taking it back for another check up.
Regards,
Willie
PS there are a numerous other posts on this subject on the forum so I take it it is not an uncommon problem. Defender Virgin
Post #19532 5th Dec 2009 5:33pm
jamesbond007
It gets pretty annoying this klong for sure.
It was worse with the BAS remap, so I went back to the original map. Boldly going nowhere
Post #19533 5th Dec 2009 6:14pm
eutek
Not possessing the appropriate sized spanners (we recently moved and as such have next to no tools!), I've tried shifting earlier and use the torque to pull me along. This actually makes it worse, and I clunk in every gear.
I usually do what Willie describes, and slightly rev before engaging the clutch - this seems to work well. Any hesitation when re-applying the pedal after a shift however usually results in a disconcerting "clunk".
Post #19580 7th Dec 2009 10:35am
jamesbond007
yep
Sad Boldly going nowhere
Post #19581 7th Dec 2009 10:39am
Niel
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
I am getting my 110 back today after it spent a week with the dealers.
This clucky-ness was one of my main complaints. They have replaced the gearbox and clutch. Will let you know if it is any better. Puma 110 sw White
No extras yet.
Post #19681 9th Dec 2009 5:30am
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Why on earth can't LR admit they have an issue with transmission backlash and a dodgy Transit gearbox, rather than trying to pass it off as "characteristisc of the marque". A load of "bo****ks" if you ask me. Just trying to save a few bob with poor product development and the consequential warranty issues (poorly addressed at that!). Shame, as there is a great Defender following out there (me included), but how long it will last with current product, I shudder to think!!! There was me thinking FMC would make it better.
Yours,
One nPi**ed of TDCi Defender owner.
Post #19862 11th Dec 2009 8:50pm
MK
Who really knows where the clunk is coming from. I donīt think it is the clutch. So ruling it out, the only candidates for serious clonks are the GB or the TC. You can figure out how to proceed, unless both come with factory clunk. Anyway in my case I didn`t have any noise until I got 5000 miles on the clock.
Do transits have clonks with the MT82? Puma 110" SW
Post #19898 11th Dec 2009 11:34pm
peanutbob
i think this is a bit unfair on L/R! When i got my 110 in September, I became very aware that changing from 1st to 2nd, and 2nd to third gears there was a noticeable clunk. After 3000 miles this had become unoticeable entirely due to me changing gears properly - i.e. taking up the slight slack that is always built in. So, I don't believe there is an issue here, you just have to address your driving to the box and engine and then you will find it ok. It's a bit like commercial vehicles really, once you have driven a van or truck for a while you get a feel for it. After 5000 miles in 3 months in my 110 puma it just gets better! I would add that after 1000 miles, I was slightly concerned ref the clunk, but not any more! I have the gear change smooth now. If you've driven Land Rovers before from their inception, you always will bed in wiith them. How may dealers have changed transmissions for little reason, I wonder.
Post #19899 11th Dec 2009 11:37pm
MK
If that is the price to drive a LR? Never got that on any other car. Not even on a LADA! So I also wonder. Puma 110" SW
Post #19902 12th Dec 2009 12:04am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I had all the same clunks and gratings of 1 & 2 but new gear box and it's like a dream, The difference is not comparable, Its not the same vehicle Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #19903 12th Dec 2009 12:45am
