Home > Off Topic > Towing a trailer with led lights |
jasong4110 Member Since: 18 Oct 2009 Location: Henley On Thames Posts: 268 |
When I built my trailer I used LED lights and had the same issue I ended up fitting ballast resistors to the indicators to make them function correctly and my towing tell tale work correctly. I chose to do it this way rather than changing the flasher unit as I tow other trailers and it would have messed the flashing rate on these up.
Jason. Last edited by jasong4110 on 13th Dec 2012 10:57pm. Edited 1 time in total |
13th Dec 2012 10:54pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
You need to change the flasher relay in the Disco for one which supports LED lights. There's loads on ebay or alternatively PM Tim at The Mobilecentre who's a site sponsor on here as he carries them.
Pete |
13th Dec 2012 10:55pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
It is definatly a cure but they do flash a bit slow for my liking If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
13th Dec 2012 11:02pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
No flasher relay in a D3 as such (body controller), you will need ballasts or hidden bulbs I'm afraid 1988 90 Td5 NAS soft top
2015 D90 XS SW |
13th Dec 2012 11:03pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
He has others that cure the slow flash as well the early relays did this not the newer ones |
14th Dec 2012 6:55am |
