Home > Off Topic > Towing a trailer with led lights
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Does anyone know how to cure this problem I have fitted my ifor Williams with all led lights great on my defender if I tow it with my old mans disco 3 the indocators have a small pulse constant any idea how to cure this
Post #193328 13th Dec 2012 10:45pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
When I built my trailer I used LED lights and had the same issue I ended up fitting ballast resistors to the indicators to make them function correctly and my towing tell tale work correctly. I chose to do it this way rather than changing the flasher unit as I tow other trailers and it would have messed the flashing rate on these up.
Jason.
Post #193332 13th Dec 2012 10:54pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
You need to change the flasher relay in the Disco for one which supports LED lights. There's loads on ebay or alternatively PM Tim at The Mobilecentre who's a site sponsor on here as he carries them.
Pete
Post #193333 13th Dec 2012 10:55pm
noworries4x4
Pete
It is definatly a cure but they do flash a bit slow for my liking If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #193337 13th Dec 2012 11:02pm
Martin
Site Admin
No flasher relay in a D3 as such (body controller), you will need ballasts or hidden bulbs I'm afraid Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #193339 13th Dec 2012 11:03pm
noworries4x4 wrote:
Pete
He has others that cure the slow flash as well the early relays did this not the newer ones Thumbs Up
Post #193367 14th Dec 2012 6:55am
