Home > Maintenance & Modifications > Centre dash lighting. (bulb change) With pictures.
Did you find this guide useful?
Yes.
81%
 81%  [44]
Perhaps, I've not done it / had to do it yet.
16%
 16%  [9]
I got LR to do it for me.
1%
 1%  [1]
Total Votes: 54
Page 1 of 3 123>
1
4 As previously suggested on here by Mal (K9F) a kids drinking straw may well work well too. I however didn't have one to hand so used my method pictured.
 $W33T $0U7H3RN $UG4R
Post #192955 12th Dec 2012 4:19pm
farmer giles
very handy.
is there a single led in the horizontal heater slider controls steve, as everything else is illuminated except the bottom slider?
Post #192957 12th Dec 2012 4:23pm
I would imagine so yes. I can't see how the bulbs would illuminate those so must be LED as you say. Thumbs Up (Sorry I don't have the part number) $W33T $0U7H3RN $UG4R
Post #192958 12th Dec 2012 4:25pm
farmer giles
no worries. i have notified the dealer as its in for a service and waxoil on jan 3rd Thumbs Up
Post #192959 12th Dec 2012 4:28pm
farmer giles wrote:
very handy.
They're not LEDs, and LEDs do not work satifactorily in this application since the light output is too directional (found that out the hard way). If I recall correctly there are three bulbs altogether for the heater controls.
It is possible to replace them working through the radio aperture without disturbing the centre dash panel, but all in all it is probably easier to whip the panel out.
Post #192975 12th Dec 2012 5:35pm
Blackwolf - I think he means the illumination on the little sliders (looks like a green dot on the end) I can't see how it would be the dash illumination lighting that up due to positioning. Thumbs Up $W33T $0U7H3RN $UG4R
Post #192984 12th Dec 2012 6:12pm
Ah, you mean the little round thingy on the knob of the slider?
I think that this is done with a fibre-optic "pipe" through the knob, which catches the light from the bulb. I am pretty sure that there are no connections into the knob.
I have my entire dash in bits at the moment to wire up my heated screen, so if I remember I will have a look when I put it all back together tomorrow.
My earlier comments about the unsuitability of LEDs refer of course to the use of LEDs to replace the little capless bulbs (I tried it and it didn't work - I just got a number of very bright spots on an otherwise dark heater control panel).
Post #192993 12th Dec 2012 7:00pm
Ah I see. LED's can be very directional. It's a pity illumination colour can't be changed on the Puma but the green 'filters' on the components prevent that. regardless of coloured bulbs. $W33T $0U7H3RN $UG4R
Post #192999 12th Dec 2012 7:28pm
farmer giles
cheers blackwolf - as you say it might just be a hollow light tube as the upper slider is reasonably bright but the lower is very dim, which would tie in with Steve's pictures of dash bulb locations.
if you can confirm that would be great Thumbs Up
Post #193107 13th Dec 2012 10:13am
Naks
Thanks!
May I ask why you didn't go for LED replacements? --
Post #193133 13th Dec 2012 12:49pm
I have heard that they have an output that's too directional. Would be interesting to know what the 2.2 has though. I thought I heard that some were going LED on those. $W33T $0U7H3RN $UG4R
Post #193134 13th Dec 2012 12:52pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
so there are three lamps?! Very handy this guide...My heater controls have no lights on the right side...Maybe one or two light to replace then... Thumbs Up Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #193145 13th Dec 2012 1:48pm
There are four bulbs; one for each rotary knob and one over the centre of each slider. The slider knobs are lit by the bulbs above them and have a fibre-optic pipe from a collector on the back to the little round "light" on the knob.
If the lower slider is dark, the bulb above it has failed. The bad news is that this one is very awkward to get at!
I answered the question about replacing the bulbs with LEDs earlier in the thread.
Post #193173 13th Dec 2012 4:11pm
As Blackwolf mentions there is actually four but not showing in the picture because of the angle.
For anyone interested. I bought my bulbs from Neil @ Shukers parts. $W33T $0U7H3RN $UG4R
Post #193185 13th Dec 2012 4:42pm
farmer giles
cheers blackwolf Thumbs Up
Post #193431 14th Dec 2012 11:14am
Page 1 of 3 123>
