Home > My Defender > IKke's military 90
Page 3 of 4 <1234>
IKke
Netherlands 1986 Defender 90 200 Tdi SW Keswick Green
Thanks for the support Thud.
I finally got an MOT today after replacing the braking hose and sanding the braking pads flat. Replacing the braking hoses was a real PITA. All the gland nuts were stuck solid on the solid brake lines. So I ended up replacing the braking lines on the calipers as well. While in the process of messing with the brakes, I also adjusted the rear drum brakes. And the overall braking power is considerably better IMO Very Happy
I finished the underside of the car last week and I still have to take some photos of that. So stay tuned for some more underside shots. Mr. Green Scaling the real deal.
Post #161626 13th Aug 2012 1:51pm
K9F
Great to see the progress and glad to hear it's back on the road. Keep the pictures coming..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161636 13th Aug 2012 2:37pm
IKke
The rear area underside shots:
And it was time to wash it. There was allot of black stuff and oil on the rear. So here it is in it's current washed state.
Post #161905 14th Aug 2012 3:54pm
K9F
What an improvement on the underside in comparison to your first photos..... Thumbs Up Bet you can't resist continually dropping down and having another look... Laughing I would be!
What's next on the list? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161908 14th Aug 2012 3:58pm
IKke
Next up is sorting the oil leak. The oil filter is the prime suspect. I also think the injectors are leaking a bit so might need to have a look at them too. While changing the filter I'm also going to do an oil change.
What also needs to be done is properly tighten or even replace the turbo oil return hose as it's leaking a little bit. And tighten the belt of the alternator. But I'm afraid I'll have to take the whole wing section off to be able to reach both.
And as finishing touch I want to replace the performance air filter with a standard filter. (still looking for an air filter housing btw)
I'm also going to do the same with the battery box as what I did with the rest of the chassis.
And I still have to find the source off all the water that gets in the cab after a bit of rain. Suspects are the door windows and somewhere on the bulkhead, probably the air vents. Scaling the real deal.
Post #161917 14th Aug 2012 4:17pm
That is nice and tidy Thumbs Up
Do you only do that with Land Rovers Mal? Whistle Rolling with laughter ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #161918 14th Aug 2012 4:18pm
K9F
Off Topic No not at all...That's why I can often be found loitering at the bottom of the stairs in the atrium of the vessels I work on throwing a sneaky glance upwards.... If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161920 14th Aug 2012 4:24pm
IKke
Cheers Very Happy
Today I replaced the engine oil and oil filter. Started the engine afterwards and all was fine. Later today I tried to go for a drive but something blew. I turned the key to pre-heat. Which was fine. Then I turned to start, I heard a relay click and everything went off. Confused So a new mystery to solve and the landy is stationary once again. Sad Scaling the real deal.
Post #165476 30th Aug 2012 9:05pm
IKke
Long time since my last update.
The electrical error was solved be removing the earth cable from the chassis to the battery, resoldering the connection that is bolted to the chassis. And voilla, it even started better than ever before. The battery seemed like new again.
Then the next problem was 1 uneven wearing tire (right front). I researched what could be done with the suspension geometry and all that was possible was the tracking of the front wheels. So I made a little tool so I could do it myself. I lifted the front axle from the ground and checked for play on the bearings, just in case. That seemed fine. So next up was measuring the difference between the front of the rims and the rear. It had several mm toe in. While it needs 0-2mm toe out.
The tool is an M6 stud with a 2 bolts locked on each other on 1 side
And 2 bolts and a threaded piece of brass on the other side. I used 2 bolts on this side so that I could lock them together after measuring the small side of the wheel. Then I could move the brass piece out when measuring the other side of the wheel so. With the bolts still in the position of the small side, I could measure the distance between the bolts and the brass to measure the toe in/out. After I measured one side of the wheel I turned the wheel 180 degrees so that if it would be mounted crooked, that error would be corrected.
That was all done in september. But I can't see if it has worked because I haven't even driven 1000km with it yet.
But i did take it for a drive today after the first snow fall.
And a small vid. https://picasaweb.google.com/1169023690551...7839947602 Scaling the real deal.
Post #191627 7th Dec 2012 3:12pm
ZeDefender
Very nice - you should be proud Thumbs Up
Probably just me but I think it looks "80s" - which is how it should be Smile Tell someone you love them today because life is short.
Post #191633 7th Dec 2012 4:01pm
MartinK
Looking awesome IKke - I'll bet you are well (justifiably) chuffed with her Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #191636 7th Dec 2012 4:02pm
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Wish I'd painted mine Nato green now, thats smart mate! Thumbs Up Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #191645 7th Dec 2012 4:35pm
IKke
I am quite proud with it, but there are so many more jobs to do (it's a land rover you know Laughing). And it is an original 80's landy. 86 to be exact.
Maverick, fancy a swap Razz
Cheers for the nice comments gentleman Thumbs Up Thumbs Up Scaling the real deal.
Post #191774 8th Dec 2012 10:56am
Stoney
1996 Defender 90 300 Tdi SW Epsom Green
Great looking truck IKKe already looks so much better than when you brought it. Love the stud bar idea as well Thumbs Up
Post #191921 8th Dec 2012 9:01pm
Maverick
I think I can live with mine for now! Wink Just need to get me doors on Ben
Post #192036 9th Dec 2012 3:55pm
Page 3 of 4 <1234>
