Home > Stolen > Just had 90 xs stolen |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
I have one winging it's way to me from Simon, so I'll let you know how I get on
5th Dec 2012 1:51pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
Might be seen as a stupid question, but how does one know if a BBS is fitted.
Its a 2011 XS 110 utility, where do I look as it sounds like something that might be useful to have fitted if it isn't already there. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
5th Dec 2012 2:12pm |
Check in your hand book for the correct proceedure - but basically disconnect the battery and you'll soon know
5th Dec 2012 2:19pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
I'm sure I've read that if you disconnect the -lead from battery and the alarm sounds you've got the battery back up fitted It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 |
I start mine in gear and it has a little sound off to tell you its there haha, not intentionally started of course, towing prevention ===================================
Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
5th Dec 2012 2:33pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17563 |
There are several ways to establish if you have one, but it is also quite easy to be fooled into thinking you don't when in fact you do.
The easiest way is to disconnect the battery and see if it sounds, but you must wait long enough after stopping the engine for the system to be active first. If you do it straight away before the system is armed, it won't sound. If you look in the handbook it will tell you how to disconnect the battery without the BBS sounding, all you need to do is wait longer and it will sound. It is also easy to retrofit a BBS if you don't have one. |
5th Dec 2012 2:46pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
If yours looks like a horn Round, brass and flatish then it's non battery
If it's Square and plastic then it's the BBU unit This is the part number LR014059 Does anybody know if it's just a straight swap? |
5th Dec 2012 2:58pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Sorry to hear the bad news of the OP......... I hope she is back in your company soon.
As for the rest of the thread..... great ideas, and it is always good to compare security devices. BUT remember not to disclose the way the original system can be bypassed (as above). Yes you have spotted it and took action and other honest forum members also now know but there are thousands of others that don't- and this is a public forum where any thieving c**t can come and find out information. If not too sure, stick to pm. Just my 2p worth................... Which brings me on nicely to- Why do people give their 2p when it is only a penny for your thoughts???? Glyn |
5th Dec 2012 3:20pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
have heard of loads going lately how come there never traced
5th Dec 2012 3:27pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
German Tax Glyn
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Sorry to hear about this and hopefully you dialling 999 so quickly after the theft will help you in its recovery.
Unfortunately the Puma is easier to bypass than LR would like you to think. I can surmise from what you said they left as to how they got around to nicking it. These thief's were not amateurs and it is worrying to me now as to the amount of Pumas being stolen. The only thing I can do to stop this happening to me is to fit more physical protection in the guise of a hardcase and steering wheel disclock. Even these additional precautions can be overcome with time and if the scrots want your Puma then chances are they will get it eventually. The BBS can be retrofitted and can be put in a very hard place to remove/get to easily, unfortunately it is also a barsteward to fit it there in the first place. As its an open forum I'm not saying where, but instead use your imagination as to where it could be placed, the more awkward the better Brian. |
5th Dec 2012 4:00pm |
Me too I hope I can get a work around on the Transducer coil though? On the fitting instructions it is cable tied onto the existing loom. This should be enough as the transducer coil detector I have shows it emits a sufficient range to allow fitting of this product though I will have to make sure it starts and runs OK for at least 5 mins (passive immobiliser) before tightening the shear bolt!!!!!! Brian. |
5th Dec 2012 4:25pm |
Me too now also, been meaning to get one for ages and this has just focused the mind. He's having a bit of a run on them |
5th Dec 2012 4:38pm |
Gutted for you
5th Dec 2012 6:14pm |
