Home > Technical > Rear Light connectors
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Is it possible to buy the part which plugs into the standard rear/side/brake lights? They would need to have leads coming from them to connect to wiring on 90, so the plug part with fly lead attached (same as on a 2011 puma).
Reason being I swapped mine out when new for a set of Mobile Centre led ones so I have a set of standard lights cluttering up the garage, and my 1989 90 needs some new ones as a couple are corroded inside, so if I could use them (assuming they fit) it would get them used for something and save having to buy some more.
The lights I need to change are the stop/tail ones (at the moment anyway, might just swap the whole set over.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #189838 30th Nov 2012 4:58pm
Martin
Site Admin
I'm sure Tim does the connectors  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #189840 30th Nov 2012 5:02pm
d j hutton
Why didn't I think of that - duh
dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #189845 30th Nov 2012 5:05pm
Porny
Site Sponsor
Indeed he does...
http://www.mobilecentre.co.uk/index.php?ma...ath=36_212
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #189848 30th Nov 2012 5:13pm
d j hutton
I'll give Tim a ring on monday then, I'm after the oval shaped ones. Hopefully he'll have some - trouble is he also sells the led headlights as well Whistle and he's a silver tongued salesman!
Buy British 🇬🇧
Post #189849 30th Nov 2012 5:22pm
Just find your local automotive place, that supplies Durite stuff.
The 3 pin male "econoseal" plug that LR use is part # 0-012-43, and the female side is 0-012-53. cost about £3 each.
Bit of soldering and you're done.
Whole catalogue here for the Durite econoseal plugs
Post #189893 30th Nov 2012 7:23pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
If you want the proper crimpers, I got mine from here...
http://polevolt.co.uk/acatalog/info_TT351.html
Steve
Post #189902 30th Nov 2012 7:54pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Do you need the proper crimpers to do this, or can you make do with another crimping tool?
(I feel a Mighty Boosh sketch coming on here)
Post #189951 30th Nov 2012 10:38pm
Whenever I do these plugs (quite often), i just tin the end of the wire, lay it into the connector pin, and bend over the lugs to hold the wire in place.
Then heat up with the soldering iron, add a little more solder, and the whole lot melts into an excellent connection.
I don't usually bother to try to clamp the rubber seal into the first set of lugs, just push them up into the plastic plug/socket once the connector pin is in place.
Post #189988 1st Dec 2012 8:49am
mobilecentre
Would this make life easier
Post #190019 1st Dec 2012 11:48am
appaloosadude
Thumbs Up
Good man!
Post #190097 1st Dec 2012 5:34pm
