Home > Tdi > Clonking noise when lifting off the clutch
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
Noticed the other day when changing gear and lifting off the clutch and applying the accelerator I get a clonking noise any ideas.
Post #157774 24th Jul 2012 7:58pm
bob neville
Where from ?
If from the rear it could be the A frame ball joint.
2013 Defender 90 CSW - sold
Post #157789 24th Jul 2012 8:22pm
Tia4
Difficult to tell think near side front
Post #157790 24th Jul 2012 8:27pm
bob neville
Not that then. Could be splines on the drive shaft worn ?
Post #157794 24th Jul 2012 8:30pm
For reference: I have a '95, 300/90 and just had the front axle rebuilt due to all the bits worn out (bearings, CVs etc) mine has 103,000
hope you find the source of the sound Thumbs Up
Post #157797 24th Jul 2012 8:35pm
Myo
South Africa 2010 Defender 90 Puma 2.4 CSW Stornoway Grey
So I'm busy trawling this site looking for some answers myself.
I have a MY10 D90, 32k on the clock, clutch changed 3k ago under warranty, came back as tight as a models pert tush.
But I digress, this honeymoon lasted about a month and now, 3 months later, I had been getting more obvious drivetrain slack and then 2 days ago pulling off from a slight incline the transmission just stopped working, all I got was grinding when trying to release the clutch but no forward movement, nothing in low and diff lock.
Got towed to the dealer(LR Cape Town) after calling LR Assist and they pulled the transmission, they tell me it's a intermediate gear shaft between the gearbox and transfer box, outer splines completely worn, they also said they have never seen this on a new model so lucky me I guess. Sad
Post #181116 1st Nov 2012 8:30pm
Naks
Re: Clonking noise when lifting off the clutch
Do you mean a sharp 'clack' or a heavy 'clonk'?
The clack 'normal', a clonk is probably not. --
Post #188473 26th Nov 2012 10:07am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
check your ujs on your prop shafts Thumbs Up
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #188474 26th Nov 2012 10:10am
