![]() | Home > Puma (Tdci) > Head lights . . . |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Can't work out which way to go, got standard puma lights in my 90 with Phillips 50%brighter jobbys in, still dull as fook! On dip beam (most of my driving) can't decide weather to wire spots to dip or try some new headlights? But cheap ish £100ish? 90 Puma HT
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1785 ![]() ![]() ![]() |
Crystal headlights, re-wire through relays, 100/80 watt H4's (suitably modded with grinder as you can see the 100/80 through the crystal lens)....
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
I used IPF headlights before getting Led ones, thought they were better than the crystal ones.
What's the standard glass they come with? Ie what's in it now? Also when setting them up how is best to do so? Ie hight and convergence? 90 Puma HT
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Easiest way to set them up is take it to a garage and part with a tenner to get them to do it for you. 100% accurate!
Cheers 90 Puma HT
