Home > Puma (Tdci) > Head lights . . .
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Head lights . . .
Can't work out which way to go, got standard puma lights in my 90 with Phillips 50%brighter jobbys in, still dull as fook! On dip beam (most of my driving) can't decide weather to wire spots to dip or try some new headlights? But cheap ish £100ish? 90 Puma HT
Post #188124 24th Nov 2012 11:30pm
ickle
Crystal headlights, re-wire through relays, 100/80 watt H4's (suitably modded with grinder as you can see the 100/80 through the crystal lens).... Whistle
Post #188125 24th Nov 2012 11:36pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I used IPF headlights before getting Led ones, thought they were better than the crystal ones.
Post #188155 25th Nov 2012 8:51am
Jammer600
What's the standard glass they come with? Ie what's in it now? Also when setting them up how is best to do so? Ie hight and convergence? 90 Puma HT
Post #188160 25th Nov 2012 9:26am
rossy
Factory fit is Wipac glass (read easily smashable ! ) lights and Osram bog standard 55/60 w bulbs.
As regards set up I've not long done a search on this and as far as I gather this is the process:
1 - Measure the distance between the centre of each headlight
2 - Measure the distance from the road to the centre of one of the lights.
3 - Set the headlamp adjuster to zero.
4 - Park the Defender 4 metres from a wall. Put the lights on main beam. Then measure the distance between the brightest part of the lights on the wall. It needs to be the same as point 1 above. Then measure the height. It needs to be the same as point 2.
Unfortunately all the levels on the ground adjacent to walls around my house are wrong so I just adjusted the beam height adjuster (at the bottom of the headlight) until oncoming motorists stopped flashing me ! Job done Thumbs Up
Post #188283 25th Nov 2012 5:50pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Easiest way to set them up is take it to a garage and part with a tenner to get them to do it for you. 100% accurate!
Post #188294 25th Nov 2012 6:28pm
Jammer600
Cheers 90 Puma HT
Post #188295 25th Nov 2012 6:35pm
