Home > Maintenance & Modifications > Noisekiller or Dynamat |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 215 |
I'd go dynamat (or StP soundproofing, same product essentially but muuuuch cheaper) why? Because the noise killer is like sponge between 2layers of rubber, this traps water and stinks to high heaven! Where I used to work we threw away a lot of old noisekiller, if you are certain it will stay dry it is an excellent product! Also look at
Skins soundproofing...guess what I am doing to the 110 at the minute!? Using a mix of dynamat, StP and conveyor belt/stable matting. 1990 Defender 110 200TDI Camper - now converted to Td5 power |
23rd Nov 2012 1:47pm |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 615 |
That's brilliant, just what I needed to know, looks like its off to eBay for some dynamat. Many thanks... |
23rd Nov 2012 6:07pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Dynamat is a massive brand too. Used a lot in the USA as well in some of the very best custom vehicles / audio sponsored cars.
So Dynamat +1 from me. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
23rd Nov 2012 6:19pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Dynamat used it for years and years.
Strayed away tried cheaper brands and have now given up trying and just stick with Dynamat it is the best and worth every penny. |
23rd Nov 2012 6:21pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Ditto on Dynamat.
Noisekiller type is too heavy and doesnt mould to body and hence falls off as glue cant hold it, nor the cans of the spray stuff used afterwards. Also falls off under the bonnet. |
23rd Nov 2012 6:51pm |
If you need a hoodliner pre cut to suit Td4 give me shout
23rd Nov 2012 6:56pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Fitted Noisekiller on the 110 and it works well but ..... as said above, it drinks up the water and the first time you know it is waterlogged is when it starts leaking out. Takes forever to dry as well.
Got Dynamat in the 90 and it has been soaked a few times now and it does not absorb the water. Comparing the two, Dynamat wins hands down. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
23rd Nov 2012 9:42pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
23rd Nov 2012 10:05pm |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 |
already got bulk kit and some more sheets on order. 6 sheets have arrived and awaiting the rest
Heard of a good trick is to put it in an airing cupboard for a while to let it warm up and soften and makes it much easier to apply, much like they do in manufacturing with the wiring. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
23rd Nov 2012 10:42pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
Have to concur - go Dynamat
Been there, done that and wasted my money Tony |
26th Nov 2012 12:55pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
26th Nov 2012 1:32pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
I use Dynamat Extreme on all of our Defender builds. It's a brand I've used and trusted for many years, and will continue to use. Have recently tried a similar product from skinz, which comes in smaller sections, but was more labour intensive to install, and I questioned how effective it would be on the inside of the roof. I only used two boxes of that, and finished the rest of the car off with Dynamat. It's not cheap, but you'll only ever have to do the job once! Dynamat also sticks to the underside of the puma bonnet really well too.
I use a portable electric oil filled radiator, whenever we install this stuff. Lay a sheet over the top of the radiator, while installing a section. By the time you've finished a section, the one on the radiator will be lovely and pliable, and extremely sticky. Apply with a plastic wall paper roller. Mind the foil as well, as it'll slice through fingers easily! |
26th Nov 2012 1:33pm |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
I am led to belive that the lining of these
http://www.ebay.co.uk/itm/190759857461?ssP...1423.l2649 Makes for good, cheap, sound proofing. 2002 Defender 110 DC |
26th Nov 2012 2:16pm |
