Home > Maintenance & Modifications > Noisekiller or Dynamat
Noisekiller
14%
 14%  [3]
Dynamat
66%
 66%  [14]
Other
19%
 19%  [4]
Total Votes: 21
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
OK simple question (hopefully), as I want to install some soundproofing in my county hardtop.
I know there are number of threads related to soundproofing, but given a choice would you use Noisekiller or Dynamat and why?
Post #187469 23rd Nov 2012 1:42pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I'd go dynamat (or StP soundproofing, same product essentially but muuuuch cheaper) why? Because the noise killer is like sponge between 2layers of rubber, this traps water and stinks to high heaven! Where I used to work we threw away a lot of old noisekiller, if you are certain it will stay dry it is an excellent product! Also look at
Skins soundproofing...guess what I am doing to the 110 at the minute!? Using a mix of dynamat, StP and conveyor belt/stable matting. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #187473 23rd Nov 2012 1:47pm
dnorrishill
That's brilliant, just what I needed to know, looks like its off to eBay for some dynamat.
Many thanks...
Post #187578 23rd Nov 2012 6:07pm
Dynamat is a massive brand too. Used a lot in the USA as well in some of the very best custom vehicles / audio sponsored cars.
So Dynamat +1 from me. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #187586 23rd Nov 2012 6:19pm
mobilecentre
Dynamat used it for years and years.
Strayed away tried cheaper brands and have now given up trying and just stick with Dynamat it is the best and worth every penny.
Post #187588 23rd Nov 2012 6:21pm
Romadog
Ditto on Dynamat.
Noisekiller type is too heavy and doesnt mould to body and hence falls off as glue cant hold it, nor the cans of the spray stuff used afterwards. Also falls off under the bonnet.
Post #187604 23rd Nov 2012 6:51pm
mobilecentre
If you need a hoodliner pre cut to suit Td4 give me shout Thumbs Up
Post #187610 23rd Nov 2012 6:56pm
bob neville
Fitted Noisekiller on the 110 and it works well but ..... as said above, it drinks up the water and the first time you know it is waterlogged is when it starts leaking out. Takes forever to dry as well.
Got Dynamat in the 90 and it has been soaked a few times now and it does not absorb the water. Comparing the two, Dynamat wins hands down.
2013 Defender 90 CSW - sold
Post #187700 23rd Nov 2012 9:42pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Great - ordered noise killer today
However it is for the hard top sides so no where near water Exclamation 2007 TD5 90 Hard Top
Post #187707 23rd Nov 2012 10:05pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
already got bulk kit and some more sheets on order. 6 sheets have arrived and awaiting the rest Thumbs Up
Heard of a good trick is to put it in an airing cupboard for a while to let it warm up and soften and makes it much easier to apply, much like they do in manufacturing with the wiring. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #187716 23rd Nov 2012 10:42pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Have to concur - go Dynamat
Quote:
Ditto on Dynamat. Noisekiller type is too heavy and doesnt mould to body and hence falls off as glue cant hold it, nor the cans of the spray stuff used afterwards. Also falls off under the bonnet.
Been there, done that and wasted my money Evil or Very Mad Tony
Post #188514 26th Nov 2012 12:55pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Can always cancel under distance selling regulations...
Post #188520 26th Nov 2012 1:32pm
Alive Tuning
I use Dynamat Extreme on all of our Defender builds. It's a brand I've used and trusted for many years, and will continue to use. Have recently tried a similar product from skinz, which comes in smaller sections, but was more labour intensive to install, and I questioned how effective it would be on the inside of the roof. I only used two boxes of that, and finished the rest of the car off with Dynamat. It's not cheap, but you'll only ever have to do the job once! Dynamat also sticks to the underside of the puma bonnet really well too. Wink
I use a portable electric oil filled radiator, whenever we install this stuff. Lay a sheet over the top of the radiator, while installing a section. By the time you've finished a section, the one on the radiator will be lovely and pliable, and extremely sticky. Apply with a plastic wall paper roller.
Mind the foil as well, as it'll slice through fingers easily! Shocked
Post #188521 26th Nov 2012 1:33pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I am led to belive that the lining of these
http://www.ebay.co.uk/itm/190759857461?ssP...1423.l2649
Makes for good, cheap, sound proofing. 2002 Defender 110 DC
Post #188524 26th Nov 2012 2:16pm
