![]() | Home > Maintenance & Modifications > How do you remove the center Dash Section? |
It just pulls off mate, pull from above the heater vents on either side of the clock, there are two 'interference' fit clips on either side of the vents and two more at the bottom
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
Thanks buddy will try that and hope i dont break it lol
You wont
Well, if you do, I can sell you a new one
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6319 ![]() ![]() ![]() |
would I be right in thinking you have to remove this to get at the windscreen wiper motor?
http://www.defender2.net/forum/topic3079.html?highlight=console
http://www.defender2.net/forum/topic13695.html?highlight=dash ![]() ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 23rd Nov 2012 1:58pm. Edited 1 time in total |
Ha Ha i was waiting for that ![]() ![]() ![]() |
There's always deals to be done
Another...
![]() ![]() http://www.defender2.net/forum/topic4765.html?highlight=dash If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
K9F
![]() Im just going to pm you from now on as im just thick i think ![]() ![]() |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1312 ![]() ![]() ![]() |
Got this from another forum - there are three "tabs" along the top. First need to remove two screw in dash then lever out at the tabs
- seven in total - three along top, two on either side midway and two on either side at the bottom ![]() Click image to enlarge |
WOW
I think they've gone a bit over the top in that picture ....
