Home > Maintenance & Modifications > LED head lights |
Mine
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
21st Nov 2012 9:59pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
This is going to get messy but EU law trumps UK law here , hence why Britain got its bottom smacked for introducing dim dip a few years back and was forced by the EU to withdraw it as it did not comply. DFT makes no such exception, there may be a poorly worded statement on their website which does not offer any clarification of the law. Putting all of that to one side if you have a look at a JWS headlight it is approved under R112 which covers filament lamps so in essence ANYWHERE you can use an E approved filament headlight with R112 (Which is all Defenders) you can use the Speaker lamp. Using your point about 1989 Vehicle Lighting means through your own “facts” posted the lamps are perfectly legal as they are approved as a lamp commercially used for the last 30 years… |
21st Nov 2012 10:04pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 659 |
Certainly feeling it, with quotes like this! Hi Tim I was posting while your post was added. I'm simply stating current 'official' stance from DfT. if Bristol has approved then they need to get formal statement issued by DfT, as until they do then previous still stands. So do you have written approval from DfT that has been published on here or elsewhere? Just asking as it wold be useful to have this, again not trying to be obstructive. Cheers Steve |
21st Nov 2012 10:06pm |
This is where you are being misled, as the VCA have approved it, the DFT has no choice but to accept it. The DFT does not deal with compliance that is the VCA's job. You do not need approval from the DFT as they are unable to issue such documents because this is not what they do. The VCA issues approvals. I have the relevant approvals. Your previous also cannot stand as the LED headlights we sell are approved in essence as filament lamps. So if you are right that means every Defender made since the 1970's also has illegal headlamps as they carry the SAME approval. It also means based upon what you are saying Audi VW Lexus Bugatti Aston Martin Jaguar BMW Rolls Royce McLaren John Deere Harley Davidson Who all run LED headlamps are also illegal? I appreciate that you may feel based upon what you have read you are right, but the better way in my opinion would have been to ask the question are LED headlamps legal? Last edited by mobilecentre on 21st Nov 2012 10:29pm. Edited 1 time in total |
21st Nov 2012 10:18pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
21st Nov 2012 10:27pm |
Here's the exception wording... http://assets.dft.gov.uk/publications/dft-...dlamps.pdf Seems quite clear and doesn't appear poorly worded to me. As per your last statement, as I assume you are aware, an LED isn't a filament lamp and is therefore not legal under the 1989 regs, so no matter what e approved enclosure it won't be legal unless its retro fitted in a way that complies with Dft exception. Cheers Steve |
21st Nov 2012 10:30pm |
No this worries me. I had assumed by your previous post you knew this intimately and knew something I didn't know. Then you make statements like this about these manufacturers having cars with LED Headlamps As per above, the DfT's accepts EU Type Approval for new cars, so any car that conforms to EU type approval is ok to run HiD and LED and hence there are tons that are. This has nothing to do with retro fitting which is what I'm talking about. So as this has been debated tons of time before, where is the proof that its legal to retro fit them without meeting DfT requirements? Surely you can point me to it. No axe to grind, just looking for facts that prove they are legal to fit, as I'd personally like to have this before fitting them. Cheers Steve |
21st Nov 2012 10:40pm |
As I said this will get messy - that document provides "guidance and advice" on HID and does not even mention LED........ That document refers to the fitment of aftermarket kits into existing units - we replace the whole lamp with an approved one And so on and so on and so on. I would suggest you call Mr Stenning at the VCA who is the head of the Technical and Quality Support group and tell him he is wrong his number is 0117 951 5151 and after that all the vehicle manufacturers I have listed above and mention that all their cars & bikes are illegal. |
21st Nov 2012 10:43pm |
No need to worry - It is part of my job to understand the compliance aspect when it comes to LED when working with some of the companies above on both OEM & Aftermarket programmes. You also never even mentioned retrofit in your first post however you will notice I did. Then there is the discussion about retrofitting HID using an approved lamp in the aftermarket where you do not need levelling or washing The proof is stamped on every single LED headlamp we sell - as the law demands that |
21st Nov 2012 10:50pm |
Hi Tim
Just to be clear, 1989 legislation is the law, this does not allow you to legally have HID or LED headlamps. No ambiguity there. The above DfT doc provides guidance on their exception to this. It does not have to be legislation. So legally you can only have HID and LED headlamps on new european type approved vehicles. To retrofit you need to follow exception guidance which means fitting e approved headlamp assembly with self levelling and washers. Anything else is illegal under current UK law. There's no ambiguity here. So until DfT change their stance that's the situation. Cheers Steve |
21st Nov 2012 11:18pm |
Just to be clear Steve - you are wrong about the application. As previously offered you do not have to take my word for it - just speak to the people at the VCA or indeed VOSA who will MOT the vehicle with them fitted who of course according to your version will be failing all the cars with them fitted as an aftermarket accessory. On that one I suggest you speak to Andrew Cattell who is the Vehicle Standards Manager who I have worked with in the past with regard to the new MOT testing guidelines and the impact of LED and the requirement NOT to have washing and levelling and the subsequent redactions printed in various Land Rover magazines who said exactly the same thing you are saying then had to print an apology. I suppose their legal people were also wrong when they printed the apology for getting their facts wrong in exactly the same way as you and funnily enough one even used the same document that you have quoted The 1989 RVLR may be the law with regard to placement and operation however not to the construction of the lamps which it hands over to the UNECE so in order to comply with the 1989 RVLR you would need an ECE approved lamp fitted to say a 1996 Defender. This vehicle still complies with the RVLR if you do not alter the mounting height / position and fit a correctly ECE approved LED headlamp. As the RVLR governs position and operation. The 7” LED headlamps from JWS have a luminous flux below the level required for washing or levelling which is why they are approved under R112 which governs filament lamps (and LEDs even you say it does not even though it is clearly printed on the first page that it does ) So to recap even under the 1989 regs on their own there is no requirement for washing and levelling as the luminous flux is not great enough. All you have offered is your FYI, there is no proof at all of what you say. The document you based it on does not even mention LEDs, you keep referring to the 1989 regs however do not seem to be aware about the 1958 agreement which the UK agreed to abide by in 1963 which covered the harmonisation of vehicles and components through a Europe wide type approval process denoted by an ECE marking. There are no restrictions on this process for aftermarket or OEM hence why LR can fit a light from Hella which was produced for the aftermarket and type approve their vehicle. Then twenty years later a dealer can buy one from Wipac and fit that. Just as we sell product to vehicle manufacturers for new build or say via the Harley aftermarket to fit into a 30 year old bike. Both use the same product and both applications are legal. The point of ECE markings is to show that if fits a set of pre-determined standards required at point of production of the vehicle and then if that component needs to be changed at a later point through damage, upgrade whatever your ensure that the product meets or exceeds the original requirement in terms of safety or performance. I have worked on a refurbishment programme this year where we needed to complete all our due diligence for compliance using the 7” LED headlight as a retrofit from sealed beam so have done exactly what you say cannot be done and they have their own legislation compliance team! Suffice to say if anyone is still awake after reading this and wants to see the ECE marking then feel free to contact me or any other member with the lamps fitted and they can show you a picture, if you want to see the approval certificate then PM me. If you want to speak to the VCA or VOSA let me know and I will happily introduce you. If you need proof they pass an MOT then drop me a line as I have plenty of customers going through that process and TUV etc etc I agree there is no ambiguity - what you are saying is unfounded and misleading to this forum, I look forward to your written proof from the DFT stating replacement LED headlamps from JWS are illegal when retrofitted even if suitably E marked. I hope we all do not have to wait long as their stance is so strong. Regards Tim Last edited by mobilecentre on 22nd Nov 2012 8:25am. Edited 1 time in total |
22nd Nov 2012 12:31am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Thanks Tim that saved me a lot of typing
22nd Nov 2012 5:14am |
I hope you read all of it |
22nd Nov 2012 8:22am |
Well why didn't you say that about the light emission levels n the first place, it would have saved us both a lot of typing. I must say if you had done this amount of work, I would have thought you could have said this at the start, instead of confusing matters over eu type approval law, citing several manufacturers that run LED Headlamp and discussing MOT's.
All of your other arguments hold no sway in law, as evidenced by stance on HID being illegal for retro-fit unless you follow guidelines. I assume you agree with this? In the same way that an HID is not a filament bulb, LED, in the view of the law would be treated in the same way. However, If I understand you correctly, you have had them tested by VOSA and due to lower luminance levels, they will pass a single vehicle type approval test without self levelling and headlamp wash. Correct? So if I were to purchase a pair of JW Speaker LED headlamps, you can provide written proof of this after all of your compliance testing - yes? If so I'm happy and that's all I was asking for. Also if this is the case, it would seem to make sense to publish this on your website. As you say there's a lot of debate about this, and it may convert a few more sales for you. If anyone is unsure, this will remove any doubt. Cheers for taking the time to reply, it's been enlightening. Steve |
22nd Nov 2012 8:30am |
