![]() | Home > Technical > Light switch power load |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Just heard back from Martin regarding purchase and delivery of the Defender headlight relay loom. They can deliver to UK but there was a fault on the website so all looks good.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Update.
Websit fixed and Relay Loom ordered and paid for. 50.50 Euro delivered. Thanks VeeTee. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Was that the cost for the realy loom and replacement headlamp switch or just the relay loom and delivery to UK? |
Purchase and delivery of wiring loom only to South Wales. My switch is fine, at the moment. This is a preventative action.
Okay thanks
Just ordered mine - luckily if I pronounce Dutch words out loud with a sort of drunken accent, I can somehow understand most of them as a German/English mess
![]() But shout it at them in German because life is also terrifying and confusing... |
Ordered Monday night. Arrived today. Cannot ask for better service. The loom is fairly self explanatory. 1-to earth, 2- to battery lead on alternator. 3 & 4 to headlamp nearest alternator, 5 - to other headlamp. It would appear the difficult parts are connecting to the back of the alternator and feeding the connectors into the wings. Not sure where to run the cable across the engine bay tidily. Can't look at the moment as it is bucketing down and blowing a gale outside. Anyway if anyone has any tips on making this an easy installation then do post.
Does seem extremely well made. Very good service. ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
For those interested in this relay headlight loom here are the fitting instructions in English kindly provided by Martin, the propriteor.
The label coding: 1. Ground connection (-) This ring lug must be properly connected to a metal part of the vehicle. An existing bolt connection in the immediate vicinity of the headlights is sufficient. 2. Connection of power supply (+) This ring lug has to be mounted on the positive terminal of the alternator. Be careful with metal tools, it is recommended to first disconnect the positive terminal of the battery. 3. Control connector This male connector goes in one of the old headlight connectors. This former power feed becomes now the signal for the headlight relay in this cable loom. 4. headlight connector This connector replaces the existing headlight connector, there is no difference between left and right. 5. headlight connector This connector replaces the existing headlight connector, there is no difference between left and right. If something is not clear just give me a call during the day, customer satisfaction counts at Landreiziger. Met vriendelijke groet, Best regards Martin de Keizer. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
Hi,
nice upgrade. May I ask where the relays are supposed to be mounted? Somewhere close to the lights? Can�t find that information on their page. And as I am not with my car at the moment, the connection at the alternator is easily accesible? Thanks Oskar |
Hope to fit mine sometime in the next few weeks so will post pictures then. Should be fitted to the wing on the alternator/turbo side of the engine.
THough not exactly the same loom (I have the Swedish version), I mounted the relays on a bracket in the left wing. Also used some self-vulcanising tape to protect the relays and connectors from the elements. The alternator connection was easily accessible, just remove the back plate on the alternator to see the connections. Note: This is for the 300 Tdi motor. ![]() ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite Last edited by VeeTee on 23rd Nov 2012 9:41am. Edited 1 time in total |
Matt if you do go for the JW headlights and get them before you fit the loom don't bother fitting it you'll not need it as the load through the switch is significantly reduced. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Got the wiring all laid in and the relay block mounted and the earth fixed. Next the alternator and then the headlamp connections. BUT it's raining ++++++
