Home > Technical > Light switch power load
Page 2 of 4 <1234>
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Just heard back from Martin regarding purchase and delivery of the Defender headlight relay loom. They can deliver to UK but there was a fault on the website so all looks good. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #186451 19th Nov 2012 10:05pm
VeeTee
Netherlands
Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #186453 19th Nov 2012 10:08pm
WelshGas
Update.
Websit fixed and Relay Loom ordered and paid for. 50.50 Euro delivered.
Thanks VeeTee. LANDYWATCH
Post #186476 19th Nov 2012 11:01pm
Mo Murphy
What a useful website Smile
50 Shades of Pennine Grey
Post #186683 20th Nov 2012 8:36pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
WelshGas wrote:
Update.
Thanks VeeTee.
Was that the cost for the realy loom and replacement headlamp switch or just the relay loom and delivery to UK?
Post #186907 21st Nov 2012 5:28pm
WelshGas
Purchase and delivery of wiring loom only to South Wales. My switch is fine, at the moment. This is a preventative action. Thumbs Up LANDYWATCH
Post #186976 21st Nov 2012 8:40pm
kmac
Okay thanks
Post #186987 21st Nov 2012 9:03pm
ZeDefender
Just ordered mine - luckily if I pronounce Dutch words out loud with a sort of drunken accent, I can somehow understand most of them as a German/English mess Laughing Tell someone you love them today because life is short.
Post #186988 21st Nov 2012 9:03pm
WelshGas
Ordered Monday night. Arrived today. Cannot ask for better service. The loom is fairly self explanatory. 1-to earth, 2- to battery lead on alternator. 3 & 4 to headlamp nearest alternator, 5 - to other headlamp. It would appear the difficult parts are connecting to the back of the alternator and feeding the connectors into the wings. Not sure where to run the cable across the engine bay tidily. Can't look at the moment as it is bucketing down and blowing a gale outside. Anyway if anyone has any tips on making this an easy installation then do post.
Does seem extremely well made. Very good service. Thumbs Up LANDYWATCH
Post #187263 22nd Nov 2012 7:56pm
WelshGas
For those interested in this relay headlight loom here are the fitting instructions in English kindly provided by Martin, the propriteor.
The label coding:
1. Ground connection (-)
This ring lug must be properly connected to a metal part of the vehicle. An existing bolt connection in the immediate vicinity of the headlights is sufficient.
2. Connection of power supply (+)
This ring lug has to be mounted on the positive terminal of the alternator. Be careful with metal tools, it is recommended to first disconnect the positive terminal of the battery.
3. Control connector
This male connector goes in one of the old headlight connectors. This former power feed becomes now the signal for the headlight relay in this cable loom.
4. headlight connector
This connector replaces the existing headlight connector, there is no difference between left and right.
5. headlight connector
If something is not clear just give me a call during the day, customer satisfaction counts at Landreiziger.
Met vriendelijke groet, Best regards
Martin de Keizer. LANDYWATCH
Post #187334 22nd Nov 2012 11:05pm
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Hi,
nice upgrade. May I ask where the relays are supposed to be mounted? Somewhere close to the lights? Canīt find that information on their page. And as I am not with my car at the moment, the connection at the alternator is easily accesible?
Thanks
Oskar
Post #187354 23rd Nov 2012 1:42am
WelshGas
Hope to fit mine sometime in the next few weeks so will post pictures then. Should be fitted to the wing on the alternator/turbo side of the engine. Thumbs Up LANDYWATCH
Post #187358 23rd Nov 2012 6:36am
VeeTee
Netherlands
AlpenAndes wrote:
Hi,
Thanks
Oskar
THough not exactly the same loom (I have the Swedish version), I mounted the relays on a bracket in the left wing. Also used some self-vulcanising tape to protect the relays and connectors from the elements.
The alternator connection was easily accessible, just remove the back plate on the alternator to see the connections. Note: This is for the 300 Tdi motor.
 Cheers, Vincent
MySite
Post #187372 23rd Nov 2012 8:40am
K9F
ZeDefender wrote:
Just ordered mine -
Matt if you do go for the JW headlights and get them before you fit the loom don't bother fitting it you'll not need it as the load through the switch is significantly reduced. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #187380 23rd Nov 2012 9:14am
WelshGas
Got the wiring all laid in and the relay block mounted and the earth fixed. Next the alternator and then the headlamp connections. BUT it's raining ++++++ Censored and blowing a gale here so will have to wait. I think the alternator on the tdci is a little more problematic than yours on the 300 VeeTee, but hopefully won't take too long. Have tried to get a photo of the connections on the rear of the alternator, does anyone have one, but the ones on the www aren't that good. We shall see. LANDYWATCH
Post #187860 24th Nov 2012 4:30pm
Page 2 of 4 <1234>
