Home > Technical > Winch advice
Page 3 of 4 <1234>
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I agree Brendan the bumpers should be gaged before coating as mine has been on my truck less than 6 months and there's powder coating coming off but can't fault the actual quality of the product
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #182651 6th Nov 2012 5:43pm
jst
Goodwinch gets my vote, one of my TDS only gets used maybe 3 times a year and works faultlessly each time.
excellent value and reputation.
as a clue to how good they are look at what people are running in comps where the are used hard. TDS is bar far the most common low line electric winch, esp for mid winches. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #183076 7th Nov 2012 10:23pm
BigMike
Another vote for goodwinch. Mine gets used about once a week and I've had it for 5 years with not a single issue. I've serviced it every year. It takes a LOT of abuse.
To look after it I spray the externals (not the drum) twice a year with ACF50. No rust, no issues at all. Highly recommend them and they're bloody good value too.
Post #183247 8th Nov 2012 6:24pm
BigWheels
So..going for Goodwinch, bridge type or naked spool (solenoid at side). Any pros & cons for each? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #183809 10th Nov 2012 6:43pm
jst
bridge type is self contained, some likes the more compact looks, harder to change parts, and you can't remote the solenoids.
open type - looks cluttered with solenoids mounted on the motor, solenoids can be mounted in the engine bay out of the cr*p,, plus its easier to view the rope going on the drum.
the last reason is why i would go for a non bridge version. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #183922 11th Nov 2012 7:36am
stravaig
Scotland 2013 Defender 110 Puma 2.2 XS CSW Rimini Red
My vote WARN.
Post #257409 9th Aug 2013 12:01am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Supacat wrote:
http://www.youtube.com/watch?v=4TtAgDp6VKA
quite like the idea of this - a major issue with drum winches is getting the line to spool on correctly under load as it is nearly always a less than ideal angle you are pulling at.
This is stupid: if you dig this in the ground you'll rip it to pieces. Tge reason current mainstream winches are put IN a bumper is to protect them from impact.
Your ground clearence is reduced to about half when it's vertical.
Not a practical solution for a front bumper winch. Maybe as a top winch or a rear winch for cabbed defender though I think the extra gear will cost you the price of several replacement cables.
Post #257427 9th Aug 2013 7:29am
I see your point but stupid is perhaps going a little far - hard to rip it off if you are out of the vehicle watching from the front with normal winch linespeeds; maybe in a winch competition but then...
I think at the lowest point it's still higher than your diff.
Post #257721 10th Aug 2013 12:30pm
smb
"Stupid" is a bit harsh a word to use!
It is a Prototype so is still in development. It's good to see someone trying to solve a problem and that is what he is doing or has done. Unfortunately, whilst all the effort and imagination will solve one problem it more often than not causes a different problem. I'm sure that will be the next stage in the development.
There are plenty of self spooling devices on the market most being attached through the gearbox and shaft. The problem like with many things nowadays is that people are loosing site of what they should be doing and with winching it is keeping a close eye on what you are attached to, what the rope is doing, how the winch is working and obviously the direction your vehicle is going( assuming you are winching yourself and not others).
The inexperienced have a tendency to think that because you have a device it means you don't need to pay attention to it and this is usually when things go wrong.
It does amaze me in these times of Health & Safety that joe blogs can buy a winch and start using it without training, but that's my moan for today!!
Post #257727 10th Aug 2013 1:07pm
zone30
Sorry about the "stupid" part but the rotating is in my opinion the wrong way to go.
I do however see a solution which may work.
Just have the winch fitted like any normal winch.
The gider that goes left an right should have a gutter that can handle a bit of an angle.
Then put a bullbar that can swivel up and down on the bumper.
In the middle of that bullbar on top put 2 gutter wheels so the line is feed to the center of the winch but received from any angle. The gutter wheels take care of left and right, the swiveling bull bar does up and down.
I know a guy who built that setup without the winch gutter and it works perfectly on his 130. He uses it for very tough environments. Next weekend I 'll take a picture of it so you'd know what I mean.
Post #257860 11th Aug 2013 8:29am
BigWheels
I bought a Goodwinch KDS 10 in the end. (Its made in China, Kingone, but I hope Goodwinch waterproofed it!) Rather have black, but its gray. Short spool (100m wire rope), but fits neatly in my LR/Mantec bumper framed by the rubber A bar.
Not used yet, so still neatly wound on its spool.
What do you folks use for ground anchors when there are no trees? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #262784 31st Aug 2013 11:25pm
How much Shocked
I've used various ground anchors - old army v bar and steel pins have usually turned out the best and worst was a set of auger type pins.
The Danforth anchor type seem popular and whilst i've seen them demo'd, never used one in anger.
Post #262859 1st Sep 2013 12:35pm
zone30
Photo's of the winch bumper
Post #288368 7th Dec 2013 12:07pm
I like that Thumbs Up
Post #289829 12th Dec 2013 4:04pm
jst
Did you sort a ground anchor? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #289885 12th Dec 2013 6:09pm
Page 3 of 4 <1234>
