Home > Puma (Tdci) > searched but cant find my answer!!
laralandy
First off hi to all on the forum, It seems great, ive used this forum already and its helped me in finally buying myself a 110 xs puma and so far so good, My question is about snorkels, ive seen and read everyones views on the safari and the mantec with the hat shaped top but has anyone fitted the plastic mantec that has a mushroom top to it?? The one pictured on the silver defender at the top of this web page. The reason being i think it bolts to the wing using the existing screw holes in the vent so i dont have to drill my new toy (granted i still have to drill the pillar)
Any one use/fitted this one?? does it look a bit old fashion on a puma??
Post #181965 4th Nov 2012 1:16pm
K9F
Hi Laralandy,
Welcome to the forum, another Dorset member. Thumbs Up
Each to their own, I personally think the snorkel depicted resembles the top cowl on my woodburning stove. Most snorkels I believe will involve some form of bodywork drilling. With care and attention to detail these holes can be kept to a minimum diameter often several millimetres smaller than the instructions state and if prepared/assembled correctly will give you no further issues.
Dependant on location/time etc. etc. if you wish advice/help in fitment either myself or another Dorset forum member may be able to offer assistance.
Think this is the one you mean.....only 'advertised' as up to TD5 compatable...going rate seems to be about £160-£170...
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #181969 4th Nov 2012 1:23pm
bob neville
This is the Mantec one fitted to my TD5. No drilling of the wing as it uses the existing vent mounting holes. Three holes needed in the pillar Thumbs Up
2013 Defender 90 CSW - sold
Post #181971 4th Nov 2012 1:32pm
K9F
Will it fit a Puma? They are only 'advertised' as up to 2006 TD5 compatable. Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #181973 4th Nov 2012 1:35pm
bob neville
I have seen one fitted on a Puma locally Thumbs Up
Checked it against the 110 before I fitted it on the TD5 and could see no reason why it would not fit.
Post #181974 4th Nov 2012 1:40pm
That's the type I have (edit - I am referring to the picture in K9F's post above, th metal type) , which I actually prefer to the plastic jobbies (which remind me of the soil pipe on the outside of a house, so each to his own)! It is also (as far as I know, and please anyone correct me if I am wrong) the only type that'll fit with a roll cage.
It does however require 4 holes to be drilled in the RH of the windscreen frame for the brackets. No drilling in the wing is needed.
I am another of the sizeable Dorset contingent (Poole/Blandford area) and I am sure we could arrange for you to see my RAI if you wanted.
Post #181975 4th Nov 2012 1:41pm
K9F
Thanks for your kind and generous offer but I've a 'pole' of my own to caress and admire, also being made of plastic won't be so cold to the touch as yours.....
Shocked Rolling with laughter Shocked Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #181977 4th Nov 2012 1:49pm
laralandy
Hmmm now i am confused lol. Thats the one im thinking of bob neville, thanks to all for the replys, top lads. I have just seen one on the dreaded ebay from mps trading that claim puma fitment. But the price seems some what high considering the mantec hat plastic jobby is cheaper on paddocks and to be honest i prefer the look. I was told safari snorkels require the most drilling. I Guess ill have to man up and charge me cordless drill!! measure twice and all that lol.
Post #181978 4th Nov 2012 1:53pm
K9F
You've probably seen them already but these links may aid your decision.....
http://www.defender2.net/forum/topic7134.html?highlight=frank
http://www.defender2.net/forum/topic2105.html?highlight=frank
http://www.defender2.net/forum/topic4073.html?highlight=frank
Mantec also do a plastic jobby now too....
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...2574d5f5ef
There are lots cheaper advertised as Mantec or Safari 'STYLE'.....I personally would stick to the real deal as you will then get better quality....
Post #181980 4th Nov 2012 1:58pm
bob neville
Page two of this link at the bottom Thumbs Up
http://www.defender2.net/forum/topic12644-15.html
Shown fitted to a Puma with a cage but that is not an issue as the flexi tube will allow it back against the pillar.
Post #181981 4th Nov 2012 1:59pm
Ooh, K9, you cheeky monkey! Shocked
Post #182230 5th Nov 2012 12:07pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Vera, on here has one for sale, just taken of his SVX..Drop him PM , but i'll ring him and give a nod in this direction if you want...... Putting Dreams on Drives at JLR Solihull..
Post #182234 5th Nov 2012 12:35pm
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Thanks Ada...
The one I have is a Mantec mushroom one, which fitted to the SVX rollcage... There was no drilling involved to remove it Wink Or to fit it by the looks of things.
Make me an offer... beer, cash, naked pictures of your wife... To be fair, it's never going back on the SVX, and it's in ok nick, so it's gonna be cheap lol '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #182254 5th Nov 2012 1:11pm
laralandy
cheers but i think im going to man up and drill so i can have the mantec one, think in my heart of hearts, thats the one i want. Bye money!!
Just while im here, does anyone else seem to have a drafty 110?? i searched the forum and have heard the panel under the cubby box can leak so i taped up the trays under the seats and cubby box but i still have a breeze, no a gale coming from the back to the front. i no its landy ownership and all but its flippin freezing!!
Post #182367 5th Nov 2012 6:56pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
Can i have second dibs if it dont sell and i can collect Thumbs Up
Could you post a pic of it cheers
Post #182369 5th Nov 2012 6:57pm
