Home > Puma (Tdci) > searched but cant find my answer!!
Page 2 of 2 <12
blackwolf wrote:
It does however require 4 holes to be drilled in the RH of the windscreen frame for the brackets.
Just wondering if there is a way to fit without having to do this? Drilling the windscreen support seems a bit wrong to me.
I had a couple of Mantec snorkels fitted to Discos and whilst they were rigid, the only upper support they had was a small bolt through the rain gutter. Is this not possible on a Defender?
Alternatively, what about a right angle bracket "sikaflexed" to the windscreen support.
I noted from Brendan's Oz blog that the traditional method of fixing to the windscreen was a point of failure.
Post #182387 5th Nov 2012 7:48pm
ZeDefender
Try not to drill the frame - I just took my RAI off and one of the stainless bolts (or the rusting bracket) had started corroding the alloy. I should have used Duralac the first time but it's still a concern... Tell someone you love them today because life is short.
Post #182388 5th Nov 2012 7:51pm
Page 2 of 2 <12
