Home > Puma (Tdci) > scangauge2 |
steveandlooby Member Since: 07 Nov 2009 Location: Bedfordshire Posts: 35 |
Does anyone know:
Can you plug a ScanGauge2 into a Puma and if so have you found it useful in monitoring performance. ps - just discovered this site whilst recovering from minor op - as a new and inexperienced owner its really useful. |
10th Nov 2009 9:18pm |
Ed Member Since: 17 Aug 2009 Location: UK Posts: 14 |
yes , i've been using one for some time now.. originally bought to monitor error codes whilst having a few teething problems and passing to and fro from the dealership..
all good now and I use it mainly for monitoring the live / average MPG and ensuring my journeys are a bit more economical |
11th Nov 2009 7:54am |
one thing of note now I remember.. as the OBD socket sits behind the fuse panel you can't fit the scanguage plug into the socket and then close the panel again.., I just popped the socket out of it's fixing and secured them behind the front speaker.
11th Nov 2009 7:56am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Dito for fitting.
Very useful for coolant temp, inlet air temp, boost, fuel consumption if required. Seems to only report a DTC if it turns the MIL on and then you can clear it. Useful: When I holed the intercooler hose and the engine went in to Limp mode, cleared, fixed, off we went again as we were miles from anywhere. Voltage was useful when my dual battery controller died (second battery died first) as I didn't have to lift the seat or bonnet to check if main battery was charging OK. Speed shown on CANbus matched that on the GPS and was usually a couple of kilometres slower than the needle on the speedometer. Annoying: Once calibrated with fuel tank size (takes a few fills) if you only partially fill or use jerry cans then you stuff up the calibration and have to start again. I found it useful when towing as I could drive more economically, also the being able to monitor the coolant temp and inlet air temp when its 47C, towing 1.5t and have 300miles to travel was better than the temp gauge on the dash. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
11th Nov 2009 10:02am |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
Were did you buy it? Matteo
Defender 110 Td4 SE MY 09 |
11th Nov 2009 10:24am |
Bought it online from their Australian site: www.scangauge.com.au
Italian site is: www.scangauge.it Also they sell on eBay. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
11th Nov 2009 11:10am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
i've removed the screw holding in the obd socket, but it seems to be held in place by the bracket it sits in, how did you remove it? also where have you guys situated the scanguage itself? i can't make my mind up |
11th Nov 2009 11:13am |
11th Nov 2009 11:23am |
how have you managed to fix it to the obd socket so you cn close the fuse flap?
11th Nov 2009 11:27am |
OBD plug is held on by a small Torx head bolt. I've undone this and the plug is then loose. I the force the cable through the hole and plug it on to the OBD socket. This holds everything in place and doesn't rattle loose. I can then close the cover and also it's easy to remove when I need to. 110 2.4TDCi
11th Nov 2009 12:19pm |
thanks very much.
11th Nov 2009 12:37pm |
Thanks for replies everyone - very helpful.
steve |
11th Nov 2009 2:26pm |
lacordaire Member Since: 22 Nov 2009 Location: Brasil Posts: 2 |
Hi guys, i'm from Brazil and bought a Scangauge to use with my Defender Puma. Where did you put the display?
8th Feb 2010 3:36pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I put grippy velcro on the back of mine and stuck it to the carpet just above the Hi/lo selector. Glyn |
9th Feb 2010 8:31am |
