Home > Puma (Tdci) > scangauge2
steveandlooby
England 2008 Defender 110 Puma 2.4 XS CSW Java Black
scangauge2
Does anyone know:
Can you plug a ScanGauge2 into a Puma and if so have you found it useful in monitoring performance.
ps - just discovered this site whilst recovering from minor op - as a new and inexperienced owner its really useful.
Post #18125 10th Nov 2009 9:18pm
shingwell
Yes, I'm using one; I bought it originally to monitor engine fault codes that the dealer said they couldn't see (I could with the scanguage!)
Apart from that, I missed not having an external air temp that my proper car has, and the scan gauge gives that. If you tell it when you fill up and £/litre, it tells you things like cost of current journey which is quite interesting and sometimes scary. The speed readout is accurate, unlike the Defender's speedo
Post #18133 10th Nov 2009 10:38pm
Ed
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
yes , i've been using one for some time now.. originally bought to monitor error codes whilst having a few teething problems and passing to and fro from the dealership..
all good now and I use it mainly for monitoring the live / average MPG and ensuring my journeys are a bit more economical Smile
Post #18140 11th Nov 2009 7:54am
Ed
one thing of note now I remember.. as the OBD socket sits behind the fuse panel you can't fit the scanguage plug into the socket and then close the panel again.., I just popped the socket out of it's fixing and secured them behind the front speaker.
Post #18141 11th Nov 2009 7:56am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Dito for fitting.
Very useful for coolant temp, inlet air temp, boost, fuel consumption if required. Seems to only report a DTC if it turns the MIL on and then you can clear it.
Useful:
When I holed the intercooler hose and the engine went in to Limp mode, cleared, fixed, off we went again as we were miles from anywhere.
Voltage was useful when my dual battery controller died (second battery died first) as I didn't have to lift the seat or bonnet to check if main battery was charging OK.
Speed shown on CANbus matched that on the GPS and was usually a couple of kilometres slower than the needle on the speedometer.
Annoying:
Once calibrated with fuel tank size (takes a few fills) if you only partially fill or use jerry cans then you stuff up the calibration and have to start again.
I found it useful when towing as I could drive more economically, also the being able to monitor the coolant temp and inlet air temp when its 47C, towing 1.5t and have 300miles to travel was better than the temp gauge on the dash. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18150 11th Nov 2009 10:02am
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Were did you buy it? Matteo
Defender 110 Td4 SE MY 09
Post #18152 11th Nov 2009 10:24am
dm_td5
Bought it online from their Australian site: www.scangauge.com.au
Italian site is: www.scangauge.it
Also they sell on eBay. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18155 11th Nov 2009 11:10am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
i've removed the screw holding in the obd socket, but it seems to be held in place by the bracket it sits in, how did you remove it? also where have you guys situated the scanguage itself? i can't make my mind up
Post #18156 11th Nov 2009 11:13am
dm_td5
Mine sits velcrod above the steering column. It does obscure the trailer flasher though. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18157 11th Nov 2009 11:23am
nicks
how have you managed to fix it to the obd socket so you cn close the fuse flap?
Post #18158 11th Nov 2009 11:27am
dm_td5
OBD plug is held on by a small Torx head bolt. I've undone this and the plug is then loose. I the force the cable through the hole and plug it on to the OBD socket. This holds everything in place and doesn't rattle loose. I can then close the cover and also it's easy to remove when I need to. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18161 11th Nov 2009 12:19pm
nicks
thanks very much.
Post #18165 11th Nov 2009 12:37pm
steveandlooby
Thanks for replies everyone - very helpful.
steve
Post #18170 11th Nov 2009 2:26pm
lacordaire
2009 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Hi guys, i'm from Brazil and bought a Scangauge to use with my Defender Puma. Where did you put the display?
Post #23850 8th Feb 2010 3:36pm
Glynparry25
I put grippy velcro on the back of mine and stuck it to the carpet just above the Hi/lo selector.
Glyn
Post #23904 9th Feb 2010 8:31am
