Home > Technical > Indicators not working - HELP - 2008 puma 90 |
yes the hazard and the indicators eses the same relay Probably the problem is related to the steering column switch Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
27th Oct 2012 4:40pm |
Bob Sheeley Member Since: 07 Jun 2011 Location: Inside M25 Posts: 18 |
Thanks; much appreciated - will try and get to that tomorrow - Bob Bob Sheeley
27th Oct 2012 4:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
As above check the switch failing that check for any shorts and also earths. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
27th Oct 2012 6:38pm |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 |
Check the back of hazard switch
If the wires come off, then the indicators stop working as well I have tried this after some off-road driving |
30th Oct 2012 2:16pm |
Thanks all for your help. It turned out to be a wire that came unsoldered to the back of the fuse board.
Bob Bob Sheeley |
1st Nov 2012 4:03pm |
