Home > Technical > Indicators not working - HELP - 2008 puma 90
Bob Sheeley
The Indicators have suddenly stopped working. I was driving along quite normally and they've suddenly stopped - I've checked both fuses - the hazard warning lights work ok (as do all of the bulbs). Does anybody know if its the same relay for the indicators as for the hazard warning lights? Anybody got any bright ideas? Thanks - Bob Bob Sheeley
Post #179498 27th Oct 2012 4:15pm
dgardel
Italy
Re: Indicators not working - HELP - 2008 puma 90
yes the hazard and the indicators eses the same relay
Probably the problem is related to the steering column switch Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #179505 27th Oct 2012 4:40pm
Bob Sheeley
Thanks; much appreciated - will try and get to that tomorrow - Bob Bob Sheeley
Post #179507 27th Oct 2012 4:48pm
As above check the switch failing that check for any shorts and also earths. Thumbs Up No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #179540 27th Oct 2012 6:38pm
mog
Denmark 2009 Defender 110 Puma 2.4 SW Alpine White
Check the back of hazard switch
If the wires come off, then the indicators stop working as well
I have tried this after some off-road driving Shocked
Post #180378 30th Oct 2012 2:16pm
Bob Sheeley
Thanks all for your help. It turned out to be a wire that came unsoldered to the back of the fuse board.
Bob Bob Sheeley
Post #181011 1st Nov 2012 4:03pm
