![]() | Home > Technical > Indicators not working - HELP - 2008 puma 90 |
yes the hazard and the indicators eses the same relay Probably the problem is related to the steering column switch Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Bob Sheeley Member Since: 07 Jun 2011 Location: Inside M25 Posts: 18 ![]() ![]() |
Thanks; much appreciated - will try and get to that tomorrow - Bob Bob Sheeley
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
As above check the switch failing that check for any shorts and also earths.
![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 ![]() ![]() ![]() |
Check the back of hazard switch
If the wires come off, then the indicators stop working as well I have tried this after some off-road driving ![]() |
Thanks all for your help. It turned out to be a wire that came unsoldered to the back of the fuse board.
Bob Bob Sheeley |
