Home > Puma (Tdci) > Which High Lift Jack?
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Santa has answered my letters and says he will buy me a high lift jack. My only problem now is which one? On flea bay there is a multitude of makes - AM Tech, Rolson, T Max, Farm Jack, Hi-Lift etc., which one should I go for?
Willie Defender Virgin
Post #17701 2nd Nov 2009 9:31pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Hi-Lift or Jackall
A lot of the others are OK but never seem to come up to the same quality.
Personally I use a Hi-Lift. MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17702 2nd Nov 2009 9:37pm
landyman1
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Thumbs Up
I agree with Hi-Lift or Jackall.
You might not need to use it much but when you do it must be reliable.
High-Lift on my wagon. Never let me down. 1981 series 3 swb gone
1986 v8 110 station wagon current
2009 puma 110 xs utility station wagon latest addition
Post #17716 2nd Nov 2009 11:05pm
jst
i use a jackel stowed on the vehicle and a HIlift for teaching on the sole grounds the hilift was 5ft and jackel 4ft when i bought them. they are the only two ladder jacks i would use. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #17862 4th Nov 2009 8:51pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
what size then for a 110 on 265 85 16?
Should I be going for 4' or 5'? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #17930 5th Nov 2009 11:11pm
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Hello,
I've never heard about 265 85 16 Shocked
Whatever, the problem is not from your tyres but from your shock absorbers. I had rear +4'' shock absorbers on my 90 and my 4ft hi-lift was too short.
Like "Mad Cow" I use Hi-lift
Thumbs Up
Post #18020 8th Nov 2009 10:26pm
Mad Cow
Well if you have those tyres that's nearly 34" diameter
Are you sure they're not 265/75 R 16? which are about 31.6" (near identical to 235/85 which I have).
The tallest truck I have had to date was a Disco on 245/75 R 16 which is a diameter of 30.5" although it did also have a 2" lift. My 4 foot Hi-Lift was just about adequete but it was easier to carry inside a Disco than a 5 foot one.
And if you are going to store it inside the vehicle, make sure it is well bolted down! MAD COW
Project90
Post #18023 8th Nov 2009 10:46pm
AndrewS
The best thing to do with a high lift jack is Throw the fooking thing away, as far as you can. Get an air jack and be safe. Thumbs Up
Stand back........ in coming Whistle
Post #18025 8th Nov 2009 11:30pm
Apynala
That's right,
Surely safer, but hi-lift has lot of kits like to jack just one wheel to put a waffle in the sand.
You don't have to dig, sand or mud, when you are stuck.
But Andrews is right, hi-lift is dangerous.
Post #18028 9th Nov 2009 9:41am
roel
I have and use air-jack and hilift. They have both there uses. An airjack is more funerable but a hilift is more dangerous.
I use the airjack when lifting is needed for changing wheels etc or in sand. But if I want to get out of ruts I prefer the hilift to jack the front or rear up and move it to next to the ruts. Roel
2003 90 Td5 (2009-now)
Post #18029 9th Nov 2009 10:03am
AndrewS
You can do this with an air Jack Thumbs Up Well you can with a Talka.
Here is a snip from the Talka web site.
http://www.takla.co.za/prod03.htm
Post #18030 9th Nov 2009 12:01pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Looks like the Takla is the one to go for then no comparison is there Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #18031 9th Nov 2009 12:12pm
roel
It might be possible with a Air-jack at the front but that is depending on your front skidplate etc. You prefer to have a sort off flat area to put the airjack under.
At the rear specially if you have no fuel tank guard and you have a moveable tow hook it's not nice to put your air-jack under.
So it's a sometimes yes and sometimes no depending on the vehicle.
With my camel it was a front no and rear yes. As I didn't have a towhook standard and had a strong tank guard. Roel
Post #18032 9th Nov 2009 12:17pm
alantd
sorry all. My bad - meant to type 265 75 16. Makes all the difference Embarassed One that started out as a 2.4 TDCi 110 XS
Post #18060 9th Nov 2009 10:22pm
alantd
Where can you get a Takla in the UK? One that started out as a 2.4 TDCi 110 XS
Post #18061 9th Nov 2009 10:24pm
