![]() | Home > Td5 > Side Window Demisters |
A perennial problem on pre-2007 Defenders is the lack of any facility for demisting the drivers and front passenger windows (apart from a cloth
![]() ![]() Click image to enlarge They are designed to fit over the existing vents and take minutes to install with the supplied longer screws. They are a bit clunky looking but don't look too out of place in the functional interior of a Defender. ![]() Click image to enlarge ![]() Click image to enlarge The view from the drivers seat isn't compromised: ![]() Click image to enlarge In use so far, they seem to do exactly what they say on the tin, which is nice. As I have a heated screen then I might experiment with blocking the top vents completely, but that's not because it's necessary. Bought them from here: www.defenderdemister.com. I've no connection other than as a satisified customer. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
I looked into those, but ended up making my own as I was after a slightly tidier solution:
http://www.retroanaconda.com/landrover/201...demisters/ I have since replaced the end outlets with more open grilles as the airflow wasn't very good to start with. Much better now ![]() |
Very neat
![]() ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
I forgot all about these, thank you for reminding me that I needed some. Ordered and on the way!
Regards, Mark |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6636 ![]() ![]() ![]() |
Their web site is wrong, wide vents arrived in 1989
