Home > Wheels & Tyres > Spare wheel carrier - again !
Page 6 of 6 <123456
JSG
leeds wrote:
John, a standard 90/110 pick up wheel carrier will NOT fit a 130.
The rear cross member is fully under the rear tub.
it would require a big bracket fitted to rear cross member to extend to back of the tub. The problem I would envisage is the leverage effect of weight of spare wheel.
I beg to differ Brendan - on any Hi-Cap you are correct but a 'standard' 130 should be ok.
This is a photo of a mate's old 130 with a wheel carrier fitted to the rear cross-member.
Edited to add; If the original question was for a 130 HC then my answer was indeed, a load of cobblers Laughing John
2011 Tdci 110 CSW XS
Post #98953 9th Nov 2011 3:55pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
That must be home built ? all 130`s have the hicap back don`t they.
Post #98954 9th Nov 2011 4:01pm
I thought that all 130's had the HC tub too.
Sonic, is your carrier still available - are you still making batches? I do get asked occasionally about the one I have on my DC, and am never quite sure what the position is. Are you the person to contact, or is it Alisport now?
After a year of using my Sonic carrier I still reckon it's the best, and can't recommend it highly enough. Apart from being the only one I have yet found that works really well with a tailgate, I also use mine to stand on to access the roofrack. Definately money well spent!
Post #98958 9th Nov 2011 4:15pm
Sonic3d
Hi Blackwolf
I have one left right now from this batch but i will be getting some more made up in the next couple of months Thumbs Up Thats the reason i came up with this design as none of the others are suitable for tailgates.
Post #98960 9th Nov 2011 4:19pm
JSG
Not sure, I know a lot are HC - perhaps they were a SV build then? John
Post #98962 9th Nov 2011 4:27pm
leeds
That is one of the 'interesting' things about Land Rovers. The number of variations that are around.
Hence why I say ensure that any piece of aftermarket kit will fit your particular Land Rover and is compatible with anything else you are likely to buy!
Sonic, I have no idea where they got the idea of high/low mount position from.
Safari do a wheel carrier for pick ups but not single pivot ones
Kaymar do a single pivot one (IIRC) for pickups. However the price is eyewatering!
Brendan
Post #98969 9th Nov 2011 4:49pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Brendan does the safari equip single pivot swing out with the door or is it a two stage operation to open the rear door?
Post #98974 9th Nov 2011 4:57pm
leeds
Kmac it is a single operation for single pivot rear door.
For the Kaymar single pivot and most of the other swingaway wheel carriers on a drop down tailgate it is a two operation opening.
HTH
Brendan
Post #98978 9th Nov 2011 5:17pm
Sonic3d wrote:
Hi Blackwolf
Are these still available and if so how much do they cost?
Post #178243 23rd Oct 2012 10:59am
Sonic3d
Contact Andy at Allisport as they are now sold through them Thumbs Up
Post #178253 23rd Oct 2012 11:24am
Page 6 of 6 <123456
