Home > Maintenance & Modifications > Parrot Asteriod
Page 2 of 2 <12
K9F
brightondefender wrote:
Thanks K9F will do - it will be the first stereo I've ever had to update software on! Whatever happened to 8-track Razz
Revived a memory or two there.....I actually in approximately 1979 ish had a Mk 1 Escort that had an 8 track fitted under the dash. Due to the size of the cartridges you'd only have room for two or three of them in the vehicle or you had to sacrifice passenger space if you wisjhed to carry more of them, slot them in and listen to the clunk and whirring before the music commenced. My how we've advanced.
Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #174781 11th Oct 2012 7:55am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Does the Asteroid allow apps such as Memory-Map to be loaded or is it restricted to Parrot authorised apps...?
Simon
Post #174791 11th Oct 2012 8:50am
SGH
Pics as promised..
Ram mount for iPhone and connectivity lead coming through air vent.
Mic on mirror base. 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #174860 11th Oct 2012 4:48pm
SGH
Pics as promised..
Post #174861 11th Oct 2012 4:49pm
brightondefender
2010 Defender 90 Puma 2.4 XS CSW Alaska White
got mine all fitted - really happy with it Smile the only slight disappointment was that I couldnt change the display to gree to match but nothing worth complaining about
quick question - where did everyone mount their GPS receiver? I have put mine on the underside of the top of the dash but not sure if it needed a line of sight to the sky..... Question
Post #175352 13th Oct 2012 12:10pm
K9F
In the middle of the top of the dash nearly touching the windscreen, in line with the clock....Line of sight is always best. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #175357 13th Oct 2012 12:17pm
Geoff 90
I got a present of a parrot asteroid for Christmas fitted it an love it it's great for streaming music to which is handy. Having a problem with it lately and I'm sure it has happened to others who have the unit. As I'm driving along it just crashes turns itself off for a few seconds and then turns itself back on again. Is it a problem with the head unit do I need to return it or is there something I can do to fix it!?
Geoff
Post #204997 24th Jan 2013 4:11pm
RobKeay
Updated mine a week ago now and it's even better.
You must reset the unit before reinstalling.
A friend of mines stopped working went completely blank.
You take the cover off and hold the reset in for 20 seconds.
Put the cover back
Put a memory stick in with the latest update
Press and hold the parrot and white button and it updates.
To reconnect your iphone you need to delete it of your connections list and re-search it.
I've put this on as I've heard a few people have said theirs has died. Having seen a dead one now full of life might be worth a go.
The update now talks English and can say people's names right. Also you say accept to answer calls which makes it proper hands free.
Also am convinced it sounds better but that is probably just me.
Post #259616 18th Aug 2013 1:03pm
Page 2 of 2 <12
